It is currently Sun Aug 17, 2025 3:39 am
Post new topic Reply to topic  [ 104 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
 Post subject: Re: Dutchy’s MiniRex
PostPosted: Thu Jul 23, 2020 7:59 pm
https://www.ausmini.com/forums/viewtopic.php?f=3&t=95872&start=75#p1054335
Project looks great, well done.
Here's the frames I made for my seats if it's any help.
1972 Mk3 Mini 1000, 1150cc supercharged.
PostPosted: Fri Jul 24, 2020 10:04 am
Cool thanks. They look good.
Website: http://www.dutchysmini.com/
Facebook page: https://www.facebook.com/Dutchysmini/
Previously owned the Red VTEC Mini (B16A)
Project currently on the go:
1961 Morris mini
Engine conversion - WRX EJ255
 Post subject: Dutchy’s MiniRex
PostPosted: Sun Jul 26, 2020 1:46 pm
For those interested in more detail and running commentary on my project I will be updating my website on a regular basis.
http://www.dutchysmini.com/minirex---page-1.html
1961 Morris mini
PostPosted: Sun Jul 26, 2020 6:24 pm
Is there any plans for the front end bodywork?
I figure you'll have the radiator up the front, it might be an opportunity to improve standard airflow with a big bonnet duct for air to exit after going through the radiator, sort of like lotus Elise bonnets do.
Roads need more corners
PostPosted: Sun Jul 26, 2020 9:00 pm
PostPosted: Sun Jul 26, 2020 11:17 pm
Yeah that! I remember it coming up in a discussion on here about the mini's aerodynamics, done properly it could help clean up a problem area near the rear of the bonnet / front of the windscreen.
PostPosted: Mon Jul 27, 2020 9:41 pm
I do like a bonnet duct and the RS3 LMS is my favourite as it almost looks factory.
While my project is going to be different I don’t want to go too far away from the mini body when it’s finished. Similar to my VTEC mini it looked like a cooper sport pack from the outside but underneath was another story.
The front will hold the radiator, fuel tank and battery at this stage.
I think I will need some additional weight to keep the front wheels down but not sure yet.
1961 Morris mini
PostPosted: Mon Jul 27, 2020 11:34 pm
It starts talking about IDF carbs but got off-topic a little in a good way, the carbon wheezel link in that thread might also be worth looking at again, it has some stuff relating to gaining front down force.
viewtopic.php?f=5&t=92566&start=30&
Trying to think of a stealthy or low key way to manage it...
PostPosted: Mon Aug 03, 2020 7:55 am
Cheers thanks.
Each day I work on this car a new challenge is thrown at me.
The MX5 su frame is going to interfere with the turbo so I’ve adapted and going to make my own frame.
Here’s some pics of what I got up to on the weekend. Not much other than ally of measuring and procrastinating until I pulled the trigger.
1961 Morris mini
PostPosted: Mon Aug 03, 2020 5:34 pm
Is it possible to move the turbo to a better location if it means the suspension / frame will be less compromised?
PostPosted: Mon Aug 03, 2020 7:20 pm
I guess it is possible however it wasn’t the only reason why I changed tact. The overall look and structure would probably look like a bitsa. So this will clean it up.
1961 Morris mini
PostPosted: Tue Aug 04, 2020 1:14 am
So just to confirm, it's a WRX engine/drivetrain and rear subframe with MX5 suspension geometry?
-Alan
PostPosted: Tue Aug 04, 2020 9:27 am
I've been thinking some more about trying to achieve a bonnet vent without it being too in your face. I'm wondering about a mechanism that pivots most of the flat part of the bonnet down from the back of the bonnet to meet up with ducting through the cooling package.
When the car isn't running it's up in the usual mini position and pivots down once the engine is running or at a particular speed or temperature.
The trick would be hiding the cut line, I remembered some rally minis have a blacked out section on the curve at the front of the bonnet a similar thing mighty disguise the cut line, sort of like 33ejb has.
It would depend on what sort of look you were going for, and it is a fair bit of effort to go to, but the sleeper aspect appeals.
PostPosted: Tue Aug 04, 2020 10:43 am
Yes that’s correct. Subframe is now custom using the lower and upper MX5 control arms
1961 Morris mini
PostPosted: Tue Aug 04, 2020 10:48 am
I love your enthusiasm for this bonnet duct.
At the moment I’m just trying to get around the engine subframe and suspension.
Keep your ideas coming though.
1961 Morris mini
Users browsing this forum: No registered users and 207 guests
