It is currently Fri Jun 20, 2025 4:46 pm
Post new topic Reply to topic  [ 104 posts ]  Go to page 1, 2, 3, 4, 5 ... 7  Next
 Post subject: Dutchy’s MiniRex
PostPosted: Mon Jul 20, 2020 9:43 pm
Hi all,
Dutchy’s mini 2.0 has started and it’s something a little bit different to the usual engine conversions on here or that I have seen on other forums too.
In summary;
1961 Morris mini with an EJ255 5spd manual. Mid mount RWD
Donor car: 2010 (MY11) WRX. Bought complete to ensure I have all the nuts and bolts I need to make this happen.
Here’s some photos of the cars and project progress so far.
Website: http://www.dutchysmini.com/
Facebook page: https://www.facebook.com/Dutchysmini/
Previously owned the Red VTEC Mini (B16A)
Project currently on the go:
1961 Morris mini
Engine conversion - WRX EJ255
 Post subject: Re: Dutchy’s MiniRex
PostPosted: Mon Jul 20, 2020 10:18 pm
1961 Morris mini
PostPosted: Mon Jul 20, 2020 10:20 pm
1961 Morris mini
PostPosted: Mon Jul 20, 2020 10:21 pm
1961 Morris mini
PostPosted: Mon Jul 20, 2020 10:22 pm
1961 Morris mini
PostPosted: Mon Jul 20, 2020 10:23 pm
That was the easy part. Now the fun begins in building the chassis & subframe.
I even threw in the seats and steering wheel to se what the future looks like.
1961 Morris mini
PostPosted: Tue Jul 21, 2020 9:17 am
Go for it Dutchy! Should have quite a punch in the rear when its done 8)
PostPosted: Tue Jul 21, 2020 9:53 am
This looks like a very interesting project. I'm not sure how the Vic rego scheme works, will it be classified as an ICV? Looking forward to following your progress.
PostPosted: Tue Jul 21, 2020 12:36 pm
jeesus, you don't muck around do you!
that WRX looks nice, was it a write-off?
PostPosted: Tue Jul 21, 2020 1:10 pm
Are you using the wrx box? There's a 2wd/fwd subaru gearbox available that I think bolts up to an ej.
I couldn't see from the photo but how close do the driveshafts line up with the position of the wheels?
Roads need more corners
PostPosted: Tue Jul 21, 2020 5:59 pm
As i am not building a chassis from scratch it is not an ICV. The applicable codes will be LA2, LB1, LG2 , LS6 and LH5/6.
And yes it will be engineered and road legal.
1961 Morris mini
PostPosted: Tue Jul 21, 2020 6:01 pm
Generally not. A little impatient :lol:
The WRX was a stat write of due to hail damage. apart from that it was a perfect car that drove well too.
Only had 100,300kms on the clock with not one modification to the engine not even a change of exhaust.
Perfect for this project.
1961 Morris mini
PostPosted: Tue Jul 21, 2020 6:13 pm
Yes I'm using the AWD 5 spd manual box but am converting it to 2WD. quite a few do it when putting the engines into beetles or Kombi's
In one of the pics is the locking collar for the gearbox and the LSD from Subarugears in WA to compliment it.
The driveshafts pretty much line up perfectly with the back wheels.
1961 Morris mini
PostPosted: Thu Jul 23, 2020 11:25 am
Wow this is great mate. We will be watching the build.
Maybe invest in some wheelie bars :)
1974 Moke - 998cc
PostPosted: Thu Jul 23, 2020 7:19 pm
Or some heavy weight in the front.
1961 Morris mini
