It is currently Wed Jul 02, 2025 1:56 pm
 Post subject: Head ID
PostPosted: Thu Jul 02, 2020 11:27 am
G'day,
Have been trying to find out what head my 850 has on it but I can't seem to find the right ones for my markings. I was told by the previous owner that he thought it may have had an 1100 head put on it at some stage but he wasn't sure.
Looking from the front of the engine with No. 1 on the RHS the marking are:
'2A3' between the valves for cyls no 1 and 2 with a '2' above this near the manifolds
'MOWOG' between the valves for cyls 2 and 3 with '71A' upside down above this near the manifolds
'21086' between the valves for cyls 3 and 4 with 'MC' above this near the manifolds.
Pics below for reference.
Thanks, Rocky
 Post subject: Re: Head ID
PostPosted: Thu Jul 02, 2020 12:07 pm
Is there any number on the thermostat end ?
PostPosted: Thu Jul 02, 2020 12:25 pm
Not that I can see Timmy.
PostPosted: Thu Jul 02, 2020 1:28 pm
All the ones I’ve seen with 21086 are 2A629 heads - stock 850 head.
To be 100% sure you might need to take off the head, but it’s possible that bigger valves have been fitted too
PostPosted: Thu Jul 02, 2020 2:05 pm
Timmy - the head has been done up and is already back on the block. Unfortunately, I didn't get a chance to measure the valves beforehand though. All I've got is a pic. I've checked the paperwork from the joint that did the head and it doesn't specify valve sizes. Just refers to a Mini 850.
No big drama whatever it is. I was talking to a bloke today who has a few minis and he was showing me some of his 1275 engines and got talking about heads etc. He mentioned that the casting numbers on the head could be used to determine what motor mine was off.
Cheers, Rocky
PostPosted: Thu Jul 02, 2020 2:43 pm
Assuming they are standard size 1” exhaust valves, the intake ones are much bigger than normal - looks like around 1.2”
It would have to be a 850/998/1098 head (not 12G295 or 206) based on the shape of the combustion chambers
PostPosted: Thu Jul 02, 2020 2:49 pm
Thanks for the info Timmy.
When I got my rocket, it was fitted with a custom set of combined inlet manifold and extractors and twin 1 1/4 SU's. Someone along the line had obviously hotted it up and looks like he might have fitted a different head as well perhaps.
He must have been a racer back in the early 60's cos he also fitted a Holden EK chrome bonnet emblem on it to make it look hotter I suppose. :D
PostPosted: Thu Jul 02, 2020 3:28 pm
does it have a boss for a temperature gauge in the front below the thermostat?
PostPosted: Thu Jul 02, 2020 5:10 pm
Hi Simon,
No boss for temp gauge on the head or block. I've put a new thermostat housing on that has provision for a gauge.
PostPosted: Thu Jul 02, 2020 7:25 pm
Hi Simon,
It's an 850 or Deluxe head.
All 1098 heads had a temp sender.
PostPosted: Thu Jul 02, 2020 7:44 pm
Thanks Doc. Did the Deluxes all have 850 motors or 998's?
Would the larger inlet valves just be a result of having the head done up and they needed to fit larger valves when they machined new seats?
Rocky
PostPosted: Thu Jul 02, 2020 8:01 pm
Deluxes are 998. It's probably a stock 850 head...
PostPosted: Fri Jul 03, 2020 7:02 am
Standard 850 and 998 inlet valves are 1.090".
Exhausts are 1.000" in all small bore heads.
PostPosted: Fri Jul 03, 2020 9:03 am
Thanks Simon and Doc.
As Timmy said, the inlet valves are much larger than the exhaust. I did a rough measurement scale on the picture of the head and if the exhaust valves are say 25mm or 1" then the inlet are roughly 30mm or about 1 3/16".
Would this increase in size be as a result of the seats being buggered and when they machined the head, they had to fit larger valves? I don't have any pics of the head when it was first taken off the motor to compare it to.
My question is just out of curiosity.
Rocky
PostPosted: Fri Jul 03, 2020 9:19 am
It's common to fit bigger valves for either better flow, or because the valve seats in the head are worn.
I did this with my 1100S head- fitted MK2 S inlets and 1.219" oversized exhausts.
No unleaded exhaust seats, I use Flashlube.
Users browsing this forum: Bing [Bot] and 76 guests
