It is currently Fri Jul 04, 2025 2:26 pm
PostPosted: Wed Jul 01, 2020 1:24 pm
Hi All,
I am looking at getting some repair sections cut out to fix my leyland clubman and the donor shell is a morris.
I wanted to check if there is any difference between the two?
Other than the obvious, lights, bonnet, front quarters.
Particularly I am interested in door and side window surrounds
Thanks
PostPosted: Wed Jul 01, 2020 3:54 pm
I don't think you'll find any differences for what you're after - I think there's a little difference around the door catch but it's minor
PostPosted: Wed Jul 01, 2020 6:01 pm
I would consider the B pillar (rear door opening section) to be significantly different .... in that you can't fit the normal round nose door latches to a Clubbie. Noting of course that later Ss and Ks had the flappy paddle door latches...
Cheers, Ian
