It is currently Sun Jul 06, 2025 6:17 am
PostPosted: Mon May 18, 2020 5:37 pm
Did Australia always use R Clips to attach the cleavis pin to the master cylinders? Some bloke is saying that they did since 1965. True?
PostPosted: Mon May 18, 2020 6:42 pm
ZPS0306.
PostPosted: Mon May 18, 2020 7:30 pm
ZPS0306.
https://www.ebay.ie/itm/ZPS0306-Pin-spl ... SwoVNaDa0H
PostPosted: Mon May 18, 2020 7:33 pm
Thanks guys
PostPosted: Mon May 18, 2020 7:49 pm
9YaTaH wrote:
That guy knows what to charge for postage!
PostPosted: Mon May 18, 2020 8:21 pm
I buy them here from Nepean Boltmaster.
Most fastener shops have them.
PostPosted: Mon May 18, 2020 8:44 pm
9YaTaH wrote:
That looks like a split pin, not an R clip :?
PostPosted: Mon May 18, 2020 9:34 pm
Split Pin
PostPosted: Tue May 19, 2020 10:37 am
So, Did Australia always use R Clips to attach the cleavis pin to the master cylinders?
Back in the days I always found and used split pins.
If so, when were they introduced?
PostPosted: Tue May 19, 2020 10:53 am
The 850 parts book only has the split pin
PostPosted: Tue May 19, 2020 10:54 am
I'm not sure they were ever "introduced". More likely is that in more recent times, R clips for the *clevis* pins have been used when the master cylinders have been removed for one reason or another and the installation of the locking pin has weighed in favour of the R clip because it is decidedly easier to insert.
PostPosted: Tue May 19, 2020 11:22 am
Some joker on Facebook was saying that R Clips were introduced to all Minis and Mokes from 1965.
PostPosted: Tue May 19, 2020 11:38 am
None of the documentation I have in parts books and change points mentions R clips being used on the brake and clutch clevis pins on Oz Minis at any time during the production period.
Are you able to ask "the joker" what supporting evidence he/she has? Like others I am always willing to learn and be corrected where new information surfaces.
PostPosted: Tue May 19, 2020 2:05 pm
Part number MYH1019 was supplied.
PostPosted: Tue May 19, 2020 3:37 pm
Here are my R clips
