It is currently Sat Jul 05, 2025 1:53 am
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Thu Oct 04, 2018 5:16 pm
https://www.ebay.co.uk/itm/Powerspark-Electronic-Distributor-for-MGB-MGB-GT-replaces-Lucas-45D-and-25D/121014415140?epid=28021593763&hash=item1c2d056f24:g:sHgAAOSwny1ajzn-
Something like this is a good price new as well.
PostPosted: Sat Oct 13, 2018 12:39 pm
Anyone know how many tapered spacers are needed for the door hinges?
67 Deluxe under going full resto
PostPosted: Sat Oct 13, 2018 2:22 pm
2 tapered washers for the top hinge. So 4 required per car
1970 Mk2 Cooper S
PostPosted: Sat Oct 13, 2018 2:59 pm
http://ausmini.com/forums/viewtopic.php?f=2&t=93191
PostPosted: Sat Oct 13, 2018 6:58 pm
Thanks for also for the extra link. Just what I need.
PostPosted: Mon Apr 13, 2020 9:39 pm
What do the orange lights on the left and right do? Thanks
PostPosted: Mon Apr 13, 2020 10:20 pm
Low oil pressure and Oil filter bypass.
On the Cooper S they only used the oil filter warning, but it was disconnected in late 1968.
PostPosted: Tue Apr 14, 2020 8:02 am
Thanks. Pretty sure there’s no sensors on my car for these. It’s has an oil pressure gauge instead of the switch.
PostPosted: Wed May 13, 2020 4:06 pm
I’m think about getting a 123 or csi dizzy. They sell vacuum advance and non vacuum advance.
As the advance is set by the programme I assume the only difference is how they look externally. Am I correct or off the mark?
PostPosted: Wed May 13, 2020 5:28 pm
The vacuum normally works in addition to any other advance. The plate inside with the points/ignition rotates when the vacuum advance is added
The 123 manual says 0 to 14 degrees more advance when vac goes from 5 to 10 inHg
PostPosted: Wed May 13, 2020 7:24 pm
Thanks so yes I need a vac advance one if I have vac advance now?
PostPosted: Wed May 13, 2020 8:52 pm
It’s a new build with a hif44 which I believe uses vac advance so from what you said look like I should by a vac advance one
PostPosted: Wed May 13, 2020 9:13 pm
Well it’s up to you. It adds extra advance at part throttle and can help with fuel economy. The Cooper S never had it
PostPosted: Wed May 13, 2020 9:18 pm
Thanks for the help
