It is currently Fri Jul 04, 2025 4:37 pm
PostPosted: Tue May 05, 2020 11:12 am
The material is a bronze alloy , which I had XRF analysed , and purchased material out of the states , I have new washers available for sale if you are interested
PostPosted: Tue May 05, 2020 11:37 am
cooperess wrote:
winabbey-Do you have the dimensions for the copper thrust washers.
No, sorry.
PostPosted: Tue May 05, 2020 12:07 pm
PM'ed 69cooper
PostPosted: Tue May 05, 2020 12:09 pm
Metallic used thrust washer measurements 54mm diameter 0.8 mm thick 27.1mm inside diameter.
PostPosted: Tue May 05, 2020 7:07 pm
I had a few sets of these new washers made many years ago for a press spring locked diff arrangement , they are 0.7 thick , material spec match's original , material was imported from US and cut using high pressure water jet ,
I do have some used original washers which I would part with for $50 a set , 2 available
Diff plates I made back in 2010
PostPosted: Tue May 05, 2020 7:34 pm
Oh wow!!
PostPosted: Tue May 05, 2020 7:42 pm
Still have one set of diff plates left , for a project that has never happened
