It is currently Sun Jul 06, 2025 12:31 am
PostPosted: Sun Jul 29, 2018 6:49 pm
Where do you get the original copper thrust washer BTA101?
PostPosted: Sun Jul 29, 2018 7:28 pm
don't know that you can get them in copper - but then all of the old diffs I've pulled apart have had fibre washers in them anyway
PostPosted: Sun Jul 29, 2018 8:30 pm
There were copper ones early on. They were in the diff of my 1966 S, but mostly they are fibre now. Look at:
http://www.guess-works.com/Shop/Parts/d ... htm?id=174
and any local parts supplier, too.
PostPosted: Sun Jul 29, 2018 9:39 pm
I have always scrounged them out of old diffs. They will dry up one day though
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Jul 29, 2018 9:51 pm
When you say dry up, you mean they will no longer be obtainable --- don't you. As they are already not available new.
PostPosted: Sun Jul 29, 2018 10:11 pm
Were only in 3 synchro boxes. I have put them in my MK 2 S box.
They are bronze not copper.
PostPosted: Mon Jul 30, 2018 7:45 am
Correct.
5/72 Clubman Gt
PostPosted: Tue Jul 31, 2018 4:29 pm
Are you sure they're bronze and not copper?
PostPosted: Tue Jul 31, 2018 5:20 pm
BTA101C
Minikingdom on line
PostPosted: Tue Jul 31, 2018 6:42 pm
Colour is too light for copper and they are hard.
I'm a machinist, I know the difference.
Note I am talking about the flat washers behind the side gears which are fibre on 4 synchro boxes.
PostPosted: Mon May 04, 2020 9:55 pm
Just wondering could these washers be sintered bronze?
PostPosted: Mon May 04, 2020 10:23 pm
Sintered bronze is brittle and porous. Mine are not. Look like sheet bronze.
Maybe are brass, but bronze is a better bearing surface.
Even brass would be better than fibre.
I don't like the currently sold fibre ones, they are too thick. Like the damned side cover gaskets are... grrr.
Why can't people make parts correctly. :x
PostPosted: Mon May 04, 2020 10:37 pm
Now I am confused "Brass" "Bronze" Sintered Bronze". Surely some here knows what material these are made of?
PostPosted: Mon May 04, 2020 11:56 pm
I believe the fibre washers are part number BTA101 and the copper the same but with a C suffix, as per the MKO link.
PostPosted: Tue May 05, 2020 8:28 am
winabbey-Do you have the dimensions for the copper thrust washers.
Users browsing this forum: Bing [Bot] and 80 guests
