It is currently Mon Jul 07, 2025 5:09 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2, 3  Next
 Post subject: Supercharged 1275
PostPosted: Sun Apr 12, 2020 11:02 am
Hi All,
I am building a Supercharged 1275 +60 and have just done the dry build. I have found the piston sits 1.52mm down the bore and has a dish of 11cc. This is giving me a compression ratio of anywhere between 7 and 9 to 1 depending on which calculator I use with most results in the 7's. I am aiming for 8.5:1 . I have tried working it out manually but maths was never a strong point so am struggling to get an accurate result.
The pistons I am currently using are NOS Mahle with a compression height of 37.13mm or 1.462in.
I don't want to skim the deck any further and am considering changing the pistons.
Does anyone have any other options or any suggestions which pistons to go for? I don't want forged due to the cost.
Thanks
 Post subject: Re: Supercharged 1275
PostPosted: Sun Apr 12, 2020 12:31 pm
I had both Russell Engineering and Hypatec when my motor had a blower, both made the required squish and bang. GR machined the dish in the RE pistons for me
PostPosted: Sun Apr 12, 2020 1:13 pm
If you want someone to check your calculations, they will need the chamber cc and possibly gasket being used.
PostPosted: Sun Apr 12, 2020 1:18 pm
Thanks.
I will be using the BK450 gasket and a 26cc chamber.
PostPosted: Sun Apr 12, 2020 2:57 pm
Your published figures equate to 8.2:1 CR
head 26.0cc
bk450 3.0cc
dish 11.0cc
deck 6.0cc (1cc per .010" bore)
total 46.0cc
1330 332.5cc per cyl
total 378.5cc
cr 8.2:1 378.5/46.0
hope this helps
For 8.5:1 you could take .020" off head
PostPosted: Sun Apr 12, 2020 7:17 pm
I am using stock Mahle pistons in a 1310 (1275LS engine). They have a slight dish. I am running about 14-15psi with no worries.
BK450 gasket, stock head (12g940 not shimmed).
Not sure what CR but it does the trick. I wouldn't worry too much as long as it in the ballpark. Just need to adjust timing curve to suit.
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
PostPosted: Sun Apr 12, 2020 10:28 pm
Thanks for the responses.
I am thinking I might settle for the 8.2:1 and if I need to I can skim the head later.
PostPosted: Sun Apr 26, 2020 7:13 pm
Another issue I have just found when putting on the timing chain. The chain appears too long. I have checked the part numbers on the box which are correct. I can think of 1 of 2 things causing it. 1- Incorrect chain in the box or 2- I have muffed something up big time. I have contacted the supplier, just awaiting a response.
Can someone please tell me that it is the chain and not me...
PostPosted: Mon Apr 27, 2020 7:35 am
Count the links, should be 52.
PostPosted: Mon Apr 27, 2020 9:31 am
I was interested so I counted the dots/pins from the photo and got 54 if that was what was supposed to be counted?
1972 Leyland Clubman, 4EFTE 1330cc Turbo, 220Hp on 17psi
(1/4 mile: 13.8s @108mph @168Hp)
PostPosted: Mon Apr 27, 2020 1:08 pm
Yes.
So it's 2 links (actually are half links) too long.
Can cut it and fit a joining link.
PostPosted: Mon Apr 27, 2020 6:53 pm
I got a call from the supplier today. They had a batch that had 54 instead of 52 links awhile back. I have now removed the 2 links and fits perfectly.
Thanks for the advice
PostPosted: Fri May 01, 2020 4:49 pm
I have a timing cover with an external oil seal. How well do they work or should I give it a miss?
Thanks
PostPosted: Tue May 05, 2020 5:31 pm
Hi
I am sorting out my primary gear now. I need to get a thrust washer so how can I work out which size to get. I don’t really want to go trial and error if it can be avoided. I don’t have a 1275 one to try. I have a new minispares gear and a backing ring and C clip. Are the backing ring and C clip the same for small and large bore?
Thanks
PostPosted: Tue May 05, 2020 10:40 pm
Yes, the thrust washer is not though.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
