It is currently Thu Jul 17, 2025 4:02 pm
 Post subject: Brake fluid sticker
PostPosted: Fri Apr 24, 2020 9:54 am
Was this sticker used on a Mk 2 S? If so, where was it located?
1970 Cooper S SPO41
 Post subject: Re: Brake fluid sticker
PostPosted: Fri Apr 24, 2020 10:58 am
No. Never seen one on a Mk2
PostPosted: Fri Apr 24, 2020 2:12 pm
Thanks, me either.
1970 Cooper S SPO41
PostPosted: Fri Apr 24, 2020 2:16 pm
My 3/70 mk2 has it fitted on the slam panel and my 4/71has it near the master cylinders.
PostPosted: Fri Apr 24, 2020 2:59 pm
Do you have the actual sticker and if so what is the size and material.
PostPosted: Fri Apr 24, 2020 3:09 pm
No, don't have the sticker. I've seen it on eBay and also either Minisport or Mini Kingdom
Sent from my SM-A305YN using Tapatalk
1970 Cooper S SPO41
PostPosted: Fri Apr 24, 2020 3:12 pm
Cooperess, do you have pictures showing the location of the sticker on your 2 cars?
1970 Cooper S SPO41
PostPosted: Fri Apr 24, 2020 3:19 pm
Sorry my mistake. I wasn't thinking of the 71S. Just ignore my comment above.
Here are 2 examples
PostPosted: Fri Apr 24, 2020 5:53 pm
Didn't "BMC" as the company name change to "British Leyland Motor Corp. long before the Mk2?
PostPosted: Fri Apr 24, 2020 6:00 pm
Many things changed at different times. If you look at ADR plates the British Leyland started with the rectangle plates in Dec 1970. The steering wheel badge change was apparently Oct 1970.
These stickers were used at least into 8/1973.
PostPosted: Fri Apr 24, 2020 6:04 pm
That fits my car. It is Sept 70 and has the BMC steering wheel
1970 Cooper S SPO41
Users browsing this forum: 63lcn and 69 guests
