It is currently Sun Jul 06, 2025 12:53 am
 Post subject: Quick conrod question
PostPosted: Wed Apr 22, 2020 1:51 pm
Hi All,
Quick question, are the 998 and 1100 conrods the same (interchangeable as a set)?
Thanks
PostPosted: Wed Apr 22, 2020 2:32 pm
Different stroke but YES they are interchangeable.
I'm not sure about all the bearings.....
And I believe the pistons and rods are different (offsets only) so 998 (maybe rods) and pistons will not work with a 1098 crank but a complete 1098 assembly will fit in a 998 block.
PostPosted: Wed Apr 22, 2020 3:03 pm
Yeah Nah
Bearings are the same. rods are the same, 998 and 1100 have different pistons and cranks.
PostPosted: Wed Apr 22, 2020 3:06 pm
998/1098 conrods come as two pairs, make sure you get a matched set with the matching caps
PostPosted: Wed Apr 22, 2020 4:22 pm
Yep I've got an 1100 crank but it only came with 3 conrods... Guy i got it from lost the 4th. But currently running a 998.
Thanks
PostPosted: Thu Apr 23, 2020 12:54 pm
There were some 998/1098 rods made by Repco (I think) that had no little end bush, they were interference fit like a 1275.
Pretty rare here though. And gudgeon pin was bigger.
