It is currently Sat Jul 05, 2025 12:24 pm
PostPosted: Mon Apr 13, 2020 6:41 pm
I have needed to replace the diff output side cover bearings on my S box and the new ones require reaming. Does anybody know the running clearance for these. Running Hardy Spicer couplings.Image
Sent from my SM-G965F using Tapatalk
1965 Smooth roof Van
1969 Cooper S MK2
1970 Mini K
PostPosted: Mon Apr 13, 2020 6:47 pm
The Doc will know
PostPosted: Mon Apr 13, 2020 8:18 pm
Go for 4 or 5 thou, 1 or 2 thou is too tight
PostPosted: Mon Apr 13, 2020 8:22 pm
Thanks for the reply. Will go with 5 thou.
1969 Cooper S MK2
1970 Mini K
PostPosted: Tue Apr 14, 2020 7:03 am
5 thou is too much, I bore them in the lathe to .002" clearance.
If they bind something is pushing the drive flange out of line, probably a bent collet inside it.
PostPosted: Tue Apr 14, 2020 9:53 am
Go with the Docs measurement. Dont worry about me - i was thinking of the freeplay when they are rocked back and forth.
