It is currently Sat Jun 21, 2025 5:47 pm
PostPosted: Fri Apr 03, 2020 8:38 am
Hi Guys,
New to this forum, Im in need of some assistance been building my mini for the past 12 years (long I KNOW) I have installed a SC 7 port head with fuel injection,
has anyone had any experience with the fuel system mapping...... the 1380 download just doesn't seem to cut it to run correctly :?: , any assistance would be much appreciated.
PostPosted: Sat Apr 04, 2020 4:23 am
What efi system are you using ? what ecu ? what are the specs are of engine ?
And whats your location ?
PostPosted: Thu Apr 09, 2020 5:18 pm
I don't know if anyone on here has an SC injected 7 port to give advice, but every engine is different anyway - what works for one persons engine could be a long way off for someone elses
the downloadable maps would give you a rough starting point that you'd work from on a dyno
I'd love to have a play with it and have a couple of friendly dyno operators who would be up for it, but I don't know where you are, what's your location? (put it in your profile)
PostPosted: Fri Apr 10, 2020 10:03 am
MiniBob on here put an SC 7-port on his Mini. viewtopic.php?f=5&t=84969
Don't know that he comes on here much nowadays but you can try him with a PM.
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
PostPosted: Sat Apr 11, 2020 5:50 pm
Well its up and running after downloading and using the SC software for my Typhoon ECU. If I recall they do different software for each version of ECU.
