It is currently Mon Jul 07, 2025 10:58 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Apr 04, 2020 2:43 pm
gtogreen1969 wrote:
40. Battery spacer
Is this for a sedan or van or moke or pickup? I have not seen this in any of my cars.
1966 Morris Mini Minor Saloon (Dot) - 1275 Auto - Mongrel
1968 Morris Mini Van (Ivan) - 998 Auto - Mongrel
1968 Morris Mini.Matic (George) - Original
1968 Morris Mini.Matic (Charlie) - Original
PostPosted: Sat Apr 04, 2020 2:44 pm
48. Dizzy advance thingy used on early 850s
PostPosted: Sat Apr 04, 2020 2:45 pm
68AUTO wrote:
gtogreen1969 wrote:
40. Battery spacer
Sedans had them in the 70s when they started using smaller batteries
PostPosted: Sat Apr 04, 2020 2:47 pm
38. Hydro bag retainers
PostPosted: Sat Apr 04, 2020 2:51 pm
43. P clamp used on fuel rail or battery lead.
PostPosted: Sat Apr 04, 2020 3:02 pm
46. Rear suspension radius arm brackets
PostPosted: Sat Apr 04, 2020 3:04 pm
32. Number plate hinge
PostPosted: Sat Apr 04, 2020 3:09 pm
25. Generator bracket
PostPosted: Sat Apr 04, 2020 3:14 pm
31. Holden Floor Pan Blanking Plate EJ - HR & WB (??)
https://www.rarespares.net.au/rarespare ... r-wb-4-pcs
9. Handbrake cable bracket - attaches to rear brake backing plate
27. Ball joint boot
41. Gear change lever retainer into remote shift housing
47. Engine steady bracket on block above clutch cover
PostPosted: Sat Apr 04, 2020 3:15 pm
10. Clutch fork for an inline engine
PostPosted: Sat Apr 04, 2020 3:21 pm
6 and 12 look like non mini disc brake caliper parts
PostPosted: Sat Apr 04, 2020 3:23 pm
Ha ha, nice try gtogreen1969. They are all "thingys" so you can't get off that easy. Try a bit harder. :)
Part #2A1007 - pipe with fuel trap, vacuum ignition control
PostPosted: Sat Apr 04, 2020 3:26 pm
Sorry mate. My brain is not working good at the moment. Just had back and neck surgery
PostPosted: Sat Apr 04, 2020 3:34 pm
I've been trying to cleanup all of the crap that I have in the shed.
There is only so much that one can know. I appreciate your help.
At least I can start to label some of this stuff and store what I need to keep.
Users browsing this forum: Jim1965 and 103 guests
