It is currently Mon Jul 07, 2025 2:07 am
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sat Apr 04, 2020 2:22 pm
Hi everyone,
I need your help to identify these bits - they could be Mini they could be something else.
Thanks to the lengthy stay at home I have had time to sort through some of my bits.
Already identified:
1. Hydro fitting
2. Thermostat housing engine stabilizer mount
4. Clubman dash trim piece
7. ?? Morris Minor clutch throw out bushes
8. Engine stabilizer bracket above clutch
9. Handbrake cable bracket - attaches to rear brake backing plate
10. Clutch fork for an inline engine
11. Passenger engine mount to engine bracket
12. Morris Minor fork pivot retainer
13. Rear brake pressure regulators
15. Alternator mounting brackets
16. Holden Floor Pan Blanking Plate EJ - HR & WB
17. Door check strap bracket
18. Remote shifter half moon rubber bung
20. Subframe tower lock tab
21. Subframe tower spacer
23. Clubby Door lock mechanism
25. Generator bracket
27. Ball joint boot
28. Battery cable retainer off a MiniMatic engine
29. Duplicate
30. Duplicate
31. Duplicate
32. Number plate hinge
34. Duplicate
35. Mini clutch over throw nut
36. MiniMatic exhaust bracket
38. Hydro bag retainers
39. Boot lock mechanism (Clubman)
40. Battery spacer
41. Gear change lever retainer into remote shift housing
42. Parcel shelf trim bracket
43. P clamp used on fuel rail or battery lead.
44. Rocker pedestal spacers
45. Clubby heater valve
46. Rear suspension radius arm brackets
47. Engine steady bracket on block above clutch cover
48. Part 2A1007 - Vacuum Pipe, with fuel trap (1959-68)
PostPosted: Sat Apr 04, 2020 2:27 pm
40. Battery spacer
PostPosted: Sat Apr 04, 2020 2:28 pm
1. Hydro fitting
PostPosted: Sat Apr 04, 2020 2:29 pm
PostPosted: Sat Apr 04, 2020 2:30 pm
PostPosted: Sat Apr 04, 2020 2:32 pm
PostPosted: Sat Apr 04, 2020 2:33 pm
PostPosted: Sat Apr 04, 2020 2:34 pm
PostPosted: Sat Apr 04, 2020 2:35 pm
PostPosted: Sat Apr 04, 2020 2:36 pm
PostPosted: Sat Apr 04, 2020 2:37 pm
PostPosted: Sat Apr 04, 2020 2:38 pm
PostPosted: Sat Apr 04, 2020 2:39 pm
I knew that that was something off of the thermostat but have never seen the engine stabilizer bracket there,
Thanks for your help!
44. Rocker pedistal spacers
PostPosted: Sat Apr 04, 2020 2:41 pm
