It is currently Sun Jul 06, 2025 3:55 am
PostPosted: Sun Mar 22, 2020 9:16 am
Hi there
I am having issues with this seal from minispares uk.
It folds over the wrong way when winding down the windows (grips on the glass and tries to go with it).
Has anyone else had issues with this?
Rick
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
PostPosted: Sun Mar 22, 2020 9:31 am
Is this the seal you are talking about? If not please post a link to what you purchased.
https://minisport.com.au/mini-outer-doo ... mium-stock
Are you aware that the wind-up window doors on Australian cars are unique to Oz and don't share parts with non-Oz minis? A purchase from Minispares UK doesn't seem right.
PostPosted: Sun Mar 22, 2020 10:37 am
Yeah, that is the one.
I must have bought them from minisport au as I can't see these listed at minispares uk.
So many purchases I didn't remember
Ford DF LTD - 5Ltr
PostPosted: Mon Mar 23, 2020 2:00 pm
Have had the same problem. Don't know whether the rubber is extra sticky or slightly too wide, so it flicks whichever way the window glass is going. It eventually stopped doing it - maybe dried out a little? I did put some chalk dust on the rubber to stop it.
When those moulds were NLA some suppliers sold the MGB part and told you to cut it to size.
PostPosted: Mon Mar 23, 2020 2:37 pm
I had the same issue. I just used a little wd40 on the finger and wiped along the edge. After a week or so it was fine.
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
PostPosted: Mon Mar 23, 2020 5:48 pm
Thank guys. I will give those ideas a go.
Ford DF LTD - 5Ltr
