It is currently Tue Jul 08, 2025 3:50 pm
PostPosted: Wed Feb 05, 2020 10:50 am
All, thinking of adding a sump guard like this one: https://minisport.com.au/mini-moke-sump ... minispares
The obvious reason for adding one is protection of the sump/gearbox from damage, but I have heard conflicting stories around oil temp, etc being an issue. At the moment I don't run an oil cooler.
Interested to hear people's thoughts, especially if you have one fitted.
67 Van, 1275cc
PostPosted: Wed Feb 05, 2020 12:49 pm
Need to add a cooler, or oil will get hotter on highway runs.
I wouldn't bother with a sump guard, except for rallying.
PostPosted: Thu Feb 06, 2020 5:50 pm
I’ve got one you can have. It weighs a ton along with any other issues they may cause, but you’re welcome to it.
PostPosted: Fri Feb 07, 2020 6:17 am
I took mine off as its a pita to do an oil change as it is with a fixed front panel.
Sent from my SM-J530Y using Tapatalk
PostPosted: Fri Feb 07, 2020 8:20 am
I'm going to take mine off as for general use I really don't think they are necessary. I agree with all of above.
PostPosted: Fri Feb 07, 2020 12:22 pm
Thanks everyone -may give it a miss based on the comments.
67 Van, 1275cc
PostPosted: Fri Feb 07, 2020 9:00 pm
I used one when I lived on a gravel road, plus my mini was rather low so the extra protection was needed. I did remove it after I raised the suspension plus I no longer have the poor road to deal with.
PostPosted: Sat Feb 08, 2020 7:16 am
I was thankful for having one on temporarily (for example) on the Wombeyan Caves road...at that time it was a logging road and the ruts were a foot deep in places...surfing on the sump guard was fun/until both wheels were off the ground at times...hmmmm :lol:
PostPosted: Sat Feb 08, 2020 8:29 am
I can say its saved my gearbox many times, if you drive rough or damaged country roads it's worth it for three piece of mind.
Roads need more corners
