It is currently Tue Jul 08, 2025 8:30 am
 Post subject: Engine colour.
PostPosted: Thu Feb 06, 2020 10:24 am
Can anyone supply a 2k paint code for the correct colour used on a 1963 mini van 850 engine please?
Had a quick troll through the forums but couldnt find anything.
Thanks.
 Post subject: Re: Engine colour.
PostPosted: Fri Feb 07, 2020 3:59 pm
Would the 850 van be the same as the Morris 850? Or were commercial vehicles different?
1963 850 - laid up
PostPosted: Fri Feb 07, 2020 5:40 pm
In 1963 it would have been the same colour as an 850, both engines then were UK made.
PostPosted: Fri Feb 07, 2020 9:42 pm
Thanks for the replies. Yes i assume both van and saloon would have same paint.
This is an austin van built in england.
Anyone know the correct colour? A code? Or a name? Or a sample?
PostPosted: Fri Feb 07, 2020 9:48 pm
I believe it was called Land Rover Bronze Green. Basically the same dark green that early Landies are usually painted...
Cheers, Ian
PostPosted: Fri Feb 07, 2020 10:02 pm
I have it listed as BS223 Mid Bronze Green. But no factory documents to prove it sorry.
There is a bit of info on the UK Forum
http://mk1-performance-conversions.co.u ... colour.htm
http://mk1-forum.net/viewtopic.php?f=3&t=14239
PostPosted: Sat Feb 08, 2020 5:55 pm
Brilliant info as usual chaps . I can chase that up and research from there! Thankyou
