It is currently Mon Jul 07, 2025 12:18 pm
PostPosted: Mon Jan 27, 2020 7:06 pm
People have been telling me that instead of fixing my gearbox I have now from a 1965 Cooper S I should just get a rebuilt one, but the ones I have found are off of standard 1275 engines. Is there a difference in gearing or am I missing something else. Right now the gearbox is connected to my 998 engine so I don't know much about the difference in gearboxes
PostPosted: Mon Jan 27, 2020 7:10 pm
Yes the ratios are quite different. I would get your MK 1 S one reconditioned to keep it original. They are worth more.
What car is it?
PostPosted: Mon Jan 27, 2020 7:18 pm
On the front of the gearbox there will be a number cast in - e.g. 22G333, 22G68 and that will tell you what type it is and where it came from
There are lots of different gear choices - normal ratio, close ratio, 4 sync, 3 sync (A or B type) and then lots of different diff ratios
PostPosted: Mon Jan 27, 2020 8:07 pm
What car is it?
It's in my 77 Leyland Sunshine. I got it with the car and I took when I took it to get thr rec done the guys at mini makeovers said it was a mid 60's cooper s gearbox.
PostPosted: Mon Jan 27, 2020 8:52 pm
What car is it?
A mid 60s Cooper S box is a 3 syncro 22G333 with a serial number 12FA xxxx. They came with a remote housing shifter.
The Sunshine had a 4 syncro Rod change style 22G1832
PostPosted: Mon Jan 27, 2020 9:05 pm
seems strange a 77 would have a mid 60s gearbox,like the others have said check the numbers on the front
PostPosted: Tue Jan 28, 2020 4:43 am
What car is it?
Take it to a proper Mini workshop and get a second opinion. Unfortunately the people you are dealing with have NFI.
Have a Nice Day.
PostPosted: Tue Jan 28, 2020 6:46 am
Beware of any repairer who says something like "its the wrong box (although it is possible), its completely shot - need a new one, I can take that old rubbish off your hands" etc
PostPosted: Tue Jan 28, 2020 10:58 am
It's not the original engine it's out of a late 60s van from the engine number
PostPosted: Tue Jan 28, 2020 11:17 am
I found this. I dont think this is the right number. I found it on the front. Is there another spot were the numbers is?
PostPosted: Tue Jan 28, 2020 11:58 am
Other side of the gearbox case - at the front under the oil filter
PostPosted: Tue Jan 28, 2020 12:12 pm
22/xxxx is the serial number given to a box fitted to the YDO 22 (M2/22 body).
Here is a pic of an early Clubman 22G1128 4 Syncro Box with a serial number 22/3721
PostPosted: Tue Jan 28, 2020 12:14 pm
Yep it says 22G**** so I should keep the gearbox. So I'm going to get the keep the gearbox. But who would would you recommend to rebuild it? I'm never rebuilt one and the last time I asked mini makeovers they said it would be $1800 to rebuild it. Who else would you guys recommend?
PostPosted: Tue Jan 28, 2020 12:30 pm
Is it 22G1832 or 22G1128?
PostPosted: Tue Jan 28, 2020 12:34 pm
There is a list of businesses here
viewtopic.php?f=41&t=83593
What is actually wrong with the gearbox now?
