It is currently Fri Aug 22, 2025 8:31 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 561, 562, 563, 564, 565, 566, 567, 568  Next
PostPosted: Fri Jan 17, 2020 9:09 pm
Looks like a fun project! I love those chrome wheel trims, do you have a complete set?
PostPosted: Sat Jan 18, 2020 6:33 am
It looks fantastic, but don't spoil the genuine patina.
Its good to see that someone finally followed the advice to not jack it up under the floor sills .... and used the roof sills instead.
Have Fun. Dave D
PostPosted: Sat Jan 18, 2020 7:53 am
Just received my new crank thread tap and cleaned out a couple of cranks . Works a treat !
67 deluxe
70 1300 auto
Simonw
Brisbane QLD
1st car - 1964 Mini Panelvan 850
Previous - 1978 Leyland LS 1275 Gold
- 1969 Mini K
PostPosted: Sat Jan 18, 2020 8:03 am
Yes Timmy a complete set as well as hubcaps in perfect condition.
Dave you should see the other shell. Someone in the past has decided to use the traditional method of strapping them to a trailer with a rope over the roof.
Am tempted to do all the repairs and leave the outside as is. Will see what direction I take when I start pulling it apart.
1963 Morris Mini 850 - Blue
1963 Morris Mini 850 - bare shell
1975 MGB Roadster - undergoing 3.9ltr V8 conversion
1998 Ducati M900 Monster
PostPosted: Fri Jan 24, 2020 12:23 pm
Drove it to work
PostPosted: Tue Apr 28, 2020 10:00 am
Flushed fuel tank and changed the plugs, running much better now - it was really struggling and low on power, my mind went to the worst case scenario of a burnt valve or glazed rings but in the end it was a simple fix!
Went on a 10hr round trip to collect my new project. An early ‘63 Morris Mini 850
The shell looks great for an unrestored car, it's amazing how well 850's stand up to rust (thanks rotodip!). Good luck with the project, looks like a good solid starting point.
+ Too many other classics
PostPosted: Tue Apr 28, 2020 10:53 am
I drove mine to fill it with 98, more litres than dollars :)
Then checked the rev limit is still set at 8500 :)
PostPosted: Tue May 19, 2020 8:00 pm
Pulled the passenger door apart on my 69 K to try and resolve a droopy handle. Good result with the handle but the door not quite all back together yet due to thunder and hail storm.
1969 Mini k
2006 Cooper S
PostPosted: Wed May 20, 2020 12:18 am
Today, I drove my Mini Cooper S to buy something at the supermarket, and at the end of the day, I took it to the car wash to clean it. On free weekends I can take time to wash my car.
PostPosted: Sun Jun 14, 2020 9:25 pm
Got some bits turn up today
I dont like oil leaks
PostPosted: Mon Jun 15, 2020 9:42 am
Replaced brake light switch, nearly gave up, so tight, felt like it had been there since 72'
Thanks Matt
PostPosted: Sat Jun 20, 2020 10:02 pm
Turned the car over today for the first time in a very long time.
Carby needle valve stuck open so just ended up with fuel all over the floor.
Tomorrow’s job.
There may be more than one way to skin a cat, but you get only one try per cat!
PostPosted: Sun Jun 21, 2020 12:13 pm
Fixed an oil leak on the oil pressure gauge line hose (std Matic and Cooper).
I replaced the 50 year old original Dunlop hose 5 years ago with the current Minispares 1/8" hose. New clamps supplied didn't clamp until fully closed up. So recently it leaked.
This time I fitted 3mm fuel injection hose. Very tight fit.
Cable ties cinched up on the ends.
No leaks now. ;)
PostPosted: Sun Jun 21, 2020 3:56 pm
Final buff after the respray and a few months for it to settle. Came up a treat.
PostPosted: Sun Jun 21, 2020 5:19 pm
Dry assembled the 1275 1100s block and did some measuring and add ups of bits needed to get it complete before sending off to the machine shop. Figured it has sat for long enough in pieces and had no spares left over. Will be 40 over and crankshaft will need a machine on the mains and big ends also. Open up the wallet and watch it get drained quickly
Rob Forsyth
Miniot!!
Users browsing this forum: No registered users and 181 guests
