The real fun has started with me dealing with the Toyota Starlet wiring loom. I pulled all the loom tube and tape off everything and using the detailed wiring document that I made years ago, I marked each connector with electrical tape - green to keep; red to remove.
![Image](https://1.bp.blogspot.com/-PGIk-iqor9w/XU1yRKg_4yI/AAAAAAAAFyQ/r9AFRCSYfx4CPtGEu6mrsLrNXea22vnCwCLcBGAs/s640/IMG_5024.jpg)
Instead of just installing the entire loom in the Mini and leaving unused wiring in place, I wanted to remove everything that I won't need - Electronic suspension, fog lights, all Air-conditioning components/sensors/relays, rear demister, rear wiper/washer, power mirrors, power windows etc. Starting at each connector, I traced each wire back to it's source, making sure it wasn't used by something else and this is what I stripped out (roll of electrical tape included for size reference
![Smile :)](./images/smilies/icon_smile.gif)
![Image](https://1.bp.blogspot.com/-TEIVGPmViTs/XV0_EQd-F9I/AAAAAAAAFz0/yky1SR7FW3wS-OBqRKfLitXmTTZ0QNLsgCLcBGAs/s640/IMG_5046.jpg)
Any wires that needed to be rejoined were done with the proper crimps
![Image](https://1.bp.blogspot.com/-jS6n8mP5wMc/XVqkYyfeqVI/AAAAAAAAFzc/XLSrvBrY2iQUfEPIphRvgZDT0pCrT5rrQCLcBGAs/s400/IMG_5044.jpg)
...and using a cheap eBay de-pin tool, I also removed all the terminal pins from the connectors
![Image](https://1.bp.blogspot.com/--iH85c4WwNs/XWpKjkb_JJI/AAAAAAAAF0c/I7r1SQKERXU08ocfWlpYWhz-jhfQt94dgCLcBGAs/s320/IMG_5048.jpg)
Just be aware that most connectors have a locking mechanism which has to be levered out before any pins can be removed
![Image](https://1.bp.blogspot.com/-McVLi-5pglE/XWpK2DLfn2I/AAAAAAAAF0o/A_diz0ZxnCUc7bInVSpUXrY-8S5CVjHNACLcBGAs/s400/IMG_5050.jpg)
After approx 12 hours of work, all the redundant wiring was removed from the cabin & engine bay looms in the Mini. I quickly found that there was not enough room in the engine bay to comfortably fit the main fuse box so I have decided that this will be relocated somewhere behind the dash and as such, a lot of re-routing of wiring will have to be done and plenty more hours work in store...
![Image](https://1.bp.blogspot.com/-Ju-d_SvL1_4/XWy2Z0_uByI/AAAAAAAAF2Q/_UuQ3_fu_U42gKm_v0umsDg83OSHVKU8gCLcBGAs/s640/IMG_5055.jpg)
I will also be adding wiring back into the loom for some gauges/sensors, dash lighting, stereo, central locking, power windows... and shortening/extending wiring for the modified positions of the alternator, battery, radiator, instrument cluster, ignition barrel.
-Alan
I blame my dad for my love of minis. I think I was conceived in the back seat of one
