It is currently Thu Jul 10, 2025 10:50 am
 Post subject: Used Crankshaft
PostPosted: Sun Nov 10, 2019 3:55 pm
Got hold of this 1098 crankshaft but has a large mark on the fly wheel end is it still ok the use or is it a boat anchor.
 Post subject: Re: Used Crankshaft
PostPosted: Sun Nov 10, 2019 4:31 pm
Boat anchor
Sent from my SM-J530Y using Tapatalk
PostPosted: Sun Nov 10, 2019 7:19 pm
Hi, I am not so sure its a boat anchor.
First I always crack test 1100 cranks before using them. An engine reconditioned can do that
Second I personally have not seen a crank break at that point, but I have seen many 1275 build up a lump on the outside at that area when one of the wrong taper UK race flywheels have been fitted , or a standard heavy A plus flywheel has fretted., or a flywheel has come loose
It does not appear to have built up, or deeply cut into the area
Three I would lap a good flywheel that you intend to use onto the crank, with valve grinding paste. You will need to see a clear seat over the full area. Thoroughly clean off the paste. If it looks good, and you know its not cracked, and not a race crank, I personally would use it
A bonus for me would be a lighter than standard flywheel/ clutch assembly, and all full balanced.If you balance it, get the balancer person to check the run out of the flywheel on the crank
Also from the photo, it appears the crank is a bit rusty, I think that is ok on the primary gear area, but never never where the engine bearings run.
Cheers Lindsay Siebler
1959 Austin A40 Farina fun car
1965 Mk1 Cooper S restored
1970 Colt 1100F SS restored
2014 Mitsubishi Imiev fully electric daily driver
1948 Allard M coupe Olds 215 v8 project
1971 Twin cam Escort ex Uk championship winning rally car project
PostPosted: Mon Nov 11, 2019 5:04 am
Online
I agree with lomin.
Re the rust, my 1275S crank laid in dirt under a house for 14 years and is pitted worse in that area.
It has since been in 3 different motors and still running fine.
And it has seen 8300 rpm on track days in the past.
PostPosted: Mon Nov 11, 2019 6:14 pm
Thanks for the replies
Think I will get it check and machined before use which is still a way off yet. But didn't want to waste time in sending it away then be told it wasn't any good.
Users browsing this forum: drmini in aust and 68 guests
