It is currently Tue Jul 01, 2025 5:52 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Sep 25, 2019 7:33 pm
AJ wrote:
Do you have any pics of your Mini Minor :P
I do, and hopefully this works!
PostPosted: Wed Sep 25, 2019 7:35 pm
Had to do one at a time as tapatalk is being painful and my photobucket is maxed out :(
PostPosted: Wed Sep 25, 2019 7:45 pm
Is that the original colour or was it Shadow Blue :P
PostPosted: Thu Sep 26, 2019 6:03 am
No, she’s always been Cedar Green. Actually wouldn’t have been my first choice but when I turned up to view the car, I was really taken with the colour!!
PostPosted: Sat Sep 28, 2019 6:29 pm
It looks good , mine is Sea Mist Green , most of them I have seen are Shadow Blue , used as fleet cars by police , post office etc , so the different colours are quite rare , I have a white one also but its in a sad condition at the moment :D
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Mon Sep 30, 2019 12:04 pm
Oh the suspense... what suggestions did you investigate and did the car start??
1972 Leyland Clubman, 4EFTE 1330cc Turbo, 220Hp on 17psi
(1/4 mile: 13.8s @108mph @168Hp)
PostPosted: Mon Sep 30, 2019 5:21 pm
:lol: I finally got myself in to the garage after a hectic weekend and have established that there is a nice strong spark (yey!) but still no go (boo!). Now to investigate potential fuel issues :?:
PostPosted: Sun Oct 06, 2019 8:58 pm
try a can of "start ya b*stard"
PostPosted: Wed Oct 09, 2019 12:22 pm
nice strong spark (yey!) @ at each and every plug electrode :?:
PostPosted: Mon Oct 28, 2019 7:46 pm
I regularly clean fouled spark plugs, I just burn them clean with a gas torch.
It works very well especially on 2 stroke motors like Victa mowers.
The easiest way to clean your 2 stroke plugs is to run them in a 4 stroke engine for a while :wink:
PostPosted: Tue Oct 29, 2019 12:22 pm
I ran my 2 stroke Victa on 50:1 outboard mix, no more fouled plugs!
My boss did the same for 20 years previously.
Regarding Minis, I have found over many years the most common reasons for fouled plugs are ancient suppression plug leads, or not enough advance at idle.
PostPosted: Thu Oct 31, 2019 1:40 pm
Interesting that yours has the deluxe grille. My Mini Minor has the 850 pressed steel grille.
What year is yours?
michael
PostPosted: Thu Oct 31, 2019 7:01 pm
Most two "smokes" foul their plugs...and will not run with wet plugs...pull the plug(s), dry them and clean the carbon deposits off then throw them back in...
PostPosted: Tue Nov 05, 2019 8:59 am
Picked up a can this week. Figured either way it is probably useful to have in the garage for the future :D
Good point... I only checked the one as quick job. Mid-week Public Holiday finally gives me chance to get back to it so I'll check all of them today. Fingers are crossed!
What year is yours?
michael
The previous owner told me that he fitted a Cooper grille as the original was stuffed, so I didn't get it with the car. She's registered as a 1964 but I'm unsure whether that is a bit too early or not. How about yours?
PostPosted: Tue Nov 05, 2019 10:23 am
Checked and all sparking nicely.
Chucked some SYB through the carb and she fired up first attempt but quickly died, so it looks like there is a problem with fueling. Not ideal but I'm pleased to be narrowing it down!
Also found out that I need a new filter on the carb so have a bit of shopping to do either way :twisted:
Thanks for everyones help so far!
