It is currently Thu Jul 17, 2025 11:20 am
 Post subject: Canberra mini mechanic
PostPosted: Sun Oct 20, 2019 7:44 pm
Hi all,
I have been building a mini from ground up for the last three years. I am now at the pointy end and need a mechanic/auto elec in/around Canberra who knows minis to take it over the line.
Any help would be greatly appreciated.
PostPosted: Mon Oct 21, 2019 10:17 am
Wayne @ Mini Works Australia is not in Canberra, but he's at the bottom end of Sydney and knows his minis
http://www.miniworksaustralia.com.au/
PostPosted: Mon Oct 21, 2019 10:45 am
This is in the list of Mini Businesses and has a Mini van in their advert - http://www.melbamotors.com/
Here's the full list - viewtopic.php?f=41&t=83593
PostPosted: Mon Oct 21, 2019 4:12 pm
benwantsamini wrote:
Hi all,
Do you want a mechanic or an auto elect? Or both?
PostPosted: Mon Oct 21, 2019 9:45 pm
Maybe you should buy a new wiring harness easy to fit A work shop manual will also help on mechanicals do what you can .I got great help from Gotto ,Bill ,Simon and all the other Masters , my Mini goes well , also fitted reco engine and gearbox.
Allen
PostPosted: Tue Oct 22, 2019 6:06 am
Thanks Simon, I’ll keep that in mind. I just don’t have a tow vehicle and would have to borrow something from work which I’d rather avoid if possible.
PostPosted: Tue Oct 22, 2019 6:07 am
I forgot about Melba Motors, thanks Winabbey.
PostPosted: Tue Oct 22, 2019 6:11 am
Hi all,
Technically both, I have bled the brakes with the Gunson easy-bleed but something still doesn’t seem right. Also the gear linkage is baffling me.
Aside from that, it’s the wiring.
PostPosted: Tue Oct 22, 2019 6:13 am
Allen
My mini is a frankenmonster so I have a new harness but it won’t really match anything from the manual (which I also have). Electrics is also not my strength :?
PostPosted: Tue Oct 22, 2019 6:50 am
Allen
Did you not get a wiring listing telling you which end of which wire connects to what? Is it an Australian built Mini or an import? Did you buy the harness from a local maker?
Are you a member of the local club? Someone there may be willing to guide you.
PostPosted: Tue Oct 22, 2019 4:43 pm
Hi all,
I have personal experience and good reports for these two...
https://www.autotechcanberra.com.au/
https://dynotune.com.au/
PostPosted: Tue Oct 22, 2019 7:28 pm
Hi all,
If they are "Mini sympathetic" and know their way around Minis I'm happy to add them to the list of Mini Businesses, but need a clear endorsement.
PostPosted: Wed Oct 23, 2019 7:24 am
Doug, both these shops are not afraid of Mini's, but more importantly, are experts at multi-carb, fuel injection etc...just about any auto sparky could sort the loom problems Cheers, Mick
PostPosted: Wed Oct 23, 2019 3:54 pm
Ben, Mick Wilson from MM knows Mini's well and can probably recommend an auto leccy if your problems need a specialist...good luck, Mick
PostPosted: Sat Oct 26, 2019 10:52 am
Hi DavidE, I did but it isn’t a very detailed diagram. To be fare I haven’t tried yet and it might not be that difficult but energy and time are also lacking.
The mini is Australian, harness is from mini sport in Adelaide and I do plan on joining a club once I get it registered. Are you a member?
