It is currently Wed Jul 09, 2025 5:30 pm
 Post subject: mk2 cs paint sticker
PostPosted: Sat Oct 19, 2019 9:29 am
Anyone know where it fits
Allen
 Post subject: Re: mk2 cs paint sticker
PostPosted: Sat Oct 19, 2019 12:25 pm
Just above the binnacle nut located halfway up the firewall behind the master cylinders.
PostPosted: Sat Oct 19, 2019 12:33 pm
Mine was where gtogreen said. It covered the body number stamp.
PostPosted: Sat Oct 19, 2019 4:16 pm
mine also covers the body number stamp - can *just* feel the numbers through the sticker
it's also more original if the sticker is placed at a slight angle, I've never seen an original one that was put on straight
PostPosted: Sat Oct 19, 2019 4:29 pm
Also - if you have a 2 tone car the top sticker is the roof colour.
PostPosted: Sat Oct 19, 2019 4:31 pm
PostPosted: Sat Oct 19, 2019 4:36 pm
cooperess wrote:
The paint is in very good condition to be original. Was the car repainted and then the sticker put in the wrong spot?
PostPosted: Sat Oct 19, 2019 8:03 pm
gtogreen1969 wrote:
Are you saying all the colour stickers are located above the captive nut?
PostPosted: Sat Oct 19, 2019 8:18 pm
Yes, All the ones I have seen on the MK2 S and Mini K.
But because it was the normal position doesn't mean that it was never put in a different spot.
PostPosted: Sun Oct 20, 2019 12:59 pm
From what I have been told by ex factory employees they used various methods to “hide”the body code stamps to prevent any confusion as these were only used as a reference internally by the body shop at the factory and not intended to be visible on a finished car. Under a paint sticker was one of these hiding spots. Also under rubber strips of drain channel, behind voltage regulators. floor of battery tray, behind compliance plate ect. ect.
PostPosted: Sun Oct 20, 2019 2:00 pm
That is interesting "floor of the battery tray".
Has anyone heard of that place?
Is that another place to look on Mk2 Mini's?
PostPosted: Sun Oct 20, 2019 2:03 pm
Not on Minis, was meaning BMC or Leyland cars generally.
PostPosted: Sun Oct 20, 2019 2:10 pm
My Mk2 has no numbers stamped on the fire wall, only the radiator shroud and the bonnet gunter.
PostPosted: Sun Oct 20, 2019 2:31 pm
The body number on a Mk2 S moved from the gutter to the firewall in June 1970.
The 850 and Cooper both had their body number hidden under the ID plate up until mid to late 1963. Then they moved to the radiator shroud
PostPosted: Sun Oct 20, 2019 3:05 pm
The Morris 1100 has the body number hidden under the removable battery tray on the inner guard.
The little wheel Moke and 998 Big Wheel Moke have the body number hidden behind the ID plate.
Users browsing this forum: Flying Brick and 109 guests
