It is currently Thu Jul 10, 2025 1:55 pm
PostPosted: Thu Oct 10, 2019 7:01 pm
Does anyone have recommendations for a source of a high quality self-adhesive tape to suit a mk 2 style wiring harness where the wiring is taped in sections - not with a continuous non-adhesive binding?
I am looking for something that stays stuck and does not unwind and bleed adhesive over everything near it. There must be something, as the factory supplier used quality stuff many years ago.
PostPosted: Thu Oct 10, 2019 7:21 pm
Ahhh.. the irony of Electrical Tape. Its neither electrical (not having any specific insulative value), or sticky (like tape).
Just go to Ideal electrical of Lawrence and Hansen or similar and get a good quality electrical tape, the one that sparkies use. Nitto is good but has its own name embossed down the center which may not be what you're after. It won't be sticky like you hoped, but there is more of a skill to wrapping then anything else including sticky. Start off, but wrap over yourself once or twice to wrap the end down before you then move along the loom. When you get to the other end, wrap carefully, and tuck the end into the wiring harness, (through the wires). This will stop it from unraveling. Also, wrap the legs off first, before you do the main harness.
I prefer woven loom wrap or other methods over tape any day, but if you're after the original look you will be fine. My mk2 loom is 11 years since re-wrapped in good tape and it still looks great.
PostPosted: Thu Oct 10, 2019 10:31 pm
Ah!
I just love your zen philosophy opening lines. I am already drawn in...
Back in consciousness, I feel you are describing the wrapping of non-adhesive type tape, which I used on the Mk1 recently. I also used an excellent cloth tape under the non-adhesive cover.
But I want to copy the later style, where the tape is only used in sections and not continuous.
I have used Nitto many years ago - made in Japan - and it was excellent, but now there are many versions that are not so excellent.
If the worst comes to it, I will use the cloth tape I bought from UK (Vehicle Wiring Products).
Thanks for your thoughts.
PostPosted: Thu Oct 10, 2019 10:41 pm
I think this is the wiring loom from "Blue MK2". It might pay to send him a message and see what he used.
PostPosted: Fri Oct 11, 2019 11:06 am
Yes, it is the same although there may be doubts, there was nothing very special about the tape. As a sparky I've dealt with a lot of old cables and tapes over the years and the stuff you will find on Mk2 Looms is just simply electrical tape. Have faith however, it will hold up with a little care. Just don't stretch the tape to snap it off, or it will unravel. Mine is still looking fine thankfully, 11 years in, and a lot of road miles!
PostPosted: Sat Oct 12, 2019 8:25 am
I will try a branded one and hope for the best.
Thanks for your comments.
PostPosted: Sat Oct 12, 2019 8:48 pm
Does anyone have any recommendations for plastic sleeve for wiring harness securing bending tabs?
Mini's I grew up with
Slot car couch
PostPosted: Sun Oct 13, 2019 7:37 am
Have a look here.
https://www.carbuilders.com.au/
They have tape which may suit. it was on display at the Motorclassica show in Melbourne.
PostPosted: Sun Oct 13, 2019 7:57 am
JayDee have loom tape
https://jaydeeautocables.com.au/collections/tape
Users browsing this forum: JM1275 and 74 guests
