It is currently Wed Jul 09, 2025 2:41 pm
 Post subject: Gear Box Help.
PostPosted: Sat Oct 05, 2019 12:12 pm
Have a gear box, remote change D 22G68 with a serial number of B47304, the lay gear only appears to have a very light stamping of what appear to be small letters BW inside stamped box, nothing else is visible, is a 3 speed syncro. Any info on what the BW might be please, do not think it is anything special.
Graham
1974 Leyland Clubman
Lots of good machines
Of all the things I have lost, I miss my mind the most.
 Post subject: Re: Gear Box Help.
PostPosted: Sat Oct 05, 2019 12:48 pm
Hi Graham, if you count all the teeth on the layshaft you can determine what it is
PostPosted: Sat Oct 05, 2019 2:05 pm
Ok, thanks Tim, will do that.
Graham
PostPosted: Sat Oct 05, 2019 5:31 pm
The BW on the gears and the B on the gearbox serial number refer to Borg Warner Australia gears. The original engine number would have finished with a B.
This would most likely be a Mini Deluxe box.
Not all cars got BW gears.
I was told by a prominent Mini parts guru that the BW gears were better quality than the English made gears.
PostPosted: Sat Oct 05, 2019 5:48 pm
I talked to Graham earlier and it’s a Morris 1100 sandwich plate remote box with standard ratio laygear and 15/64 diff ratio (4.27)
