It is currently Wed Jul 09, 2025 3:18 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Mon Sep 23, 2019 8:26 pm
A bit late as usual, I hope these pics help.
PostPosted: Mon Sep 23, 2019 8:30 pm
Was the O-ring grommet under the floor or above the floor? Mine is under the floor but i reckon it would work better on the top side to hold up/support the hose.
PostPosted: Mon Sep 23, 2019 10:12 pm
I’m fairly sure it was under. Pipe had tag which end went to pump. An o ring on top or both would be better. I dismantled the car 35 years ago , but luckily tagged nearly everything .
PostPosted: Tue Sep 24, 2019 6:30 am
Thanks for the photo's Ausdino. spot on :-)
Is the mounting of the fuel pump bracket original as well in your opinion?
Could you post some more photo's of that area if possible please.
Cheers Pete
PostPosted: Tue Sep 24, 2019 7:17 pm
Yes, I'm fairly sure it is.
Just finished another long term project, just starting to get into the Cooper S.
