It is currently Wed Jul 09, 2025 8:08 am
PostPosted: Sat Sep 21, 2019 2:25 pm
Which set of holes does the SU fuel pump support bracket attach to - the forward pair or the rear pair? I took lots of pics when disassembling everything but missed a clear shot of this section.
PostPosted: Sat Sep 21, 2019 3:15 pm
Rear.
PostPosted: Sat Sep 21, 2019 6:01 pm
Found this pic, hope this helps, never been off, only hit a few times to get it to work!
Are they big? I like 'em big!
PostPosted: Sun Sep 22, 2019 8:21 am
These may help :)
PostPosted: Sun Sep 22, 2019 9:44 am
Thanks guys. The Doc says rear but the two photos show front. ??
PostPosted: Sun Sep 22, 2019 11:17 am
Mine is bolted to the 2 fronts holes as well.
PostPosted: Sun Sep 22, 2019 11:28 am
Maybe I am wrong then. Mine is on the back 2 but car isn't original.
PostPosted: Sun Sep 22, 2019 2:02 pm
Thanks, that explains it. I realise it can go in either provided the hoses are suitable length. Just wanting to retain originality where I can. ;)
PostPosted: Sun Sep 22, 2019 3:01 pm
You were probably just mistaken Doc...I can't see you ever being wrong!! :shock: :lol:
PostPosted: Sun Sep 22, 2019 4:51 pm
Firefirey wrote:
These may help :)
Interesting the way you've mounted it Pete. When removed from mine the mounting bracket was above the subframe with bolts coming up from below then into the captive nuts, same as SMK269 photo shows.
Edit: The way you have it relies on the strength of the captive nut welds, which may be more than needed so no drama. But if they did give way the pump would drop onto the ground.
PostPosted: Sun Sep 22, 2019 6:59 pm
Doug, Did you find a supplier for the braided hose that goes to the pump and the grommet that seals it through the floor?
It looks like there are 2 parts to the grommet. A rubber sheath similar to heatshrink and a standard grommet.
I have never bought a new grommet so i was interested to see if it was 2 piece or 1 piece.
PostPosted: Sun Sep 22, 2019 9:19 pm
Hi Brad
Yes you are right - there are two parts. The rubber sleeve ( Hose ) which fits over the fuel hose is some what more substantial than heat shrink. Then not so much a grommet but a strong heavy duty o-ring fits up to the rubber sleeve. Your photo looks like the correct parts. I did reused the original parts.
My fuel pump bracket maybe fitted incorrect as Iv'e had it off a few times so thanks for the heads up Doug. I will go back and check earlier photo's :wink:
PostPosted: Sun Sep 22, 2019 10:04 pm
Firefirey wrote:
Hi Brad
Thanks. I reckon the large o-ring would do a much better job of keeping the hose in the correct position if there was one inside the boot above the floor as well.
PostPosted: Mon Sep 23, 2019 11:11 am
I have a standard piece of braided hose and haven't investigated the grommet.
PostPosted: Mon Sep 23, 2019 11:12 am
Ok. Thanks
Users browsing this forum: goodie and 89 guests
