It is currently Thu Jul 10, 2025 3:06 am
 Post subject: Painting hinges
PostPosted: Tue Sep 17, 2019 10:01 pm
Couple more questions.... what do people do when painting hinges? Do door hinges have a gasket and if so do you put door on with gaskets and paint over them? Same question with boot hinges. Seems like a dumb question but the doors didn't have any hinge gaskets when I took them off.
Thanks
 Post subject: Re: Painting hinges
PostPosted: Tue Sep 17, 2019 10:39 pm
Better to paint separately and then attach with the gasket after. If you paint them after attachment, the paint will crack as the hinge and panel flex.
PostPosted: Wed Sep 18, 2019 8:24 am
FirstMini wrote:
Do door hinges have a gasket ...
As indicated by Mick above yes they do. The usual Mini parts places can supply.
Here's one example - https://minisport.com.au/door-and-boot-lid-gasket-set
PostPosted: Wed Sep 18, 2019 1:41 pm
Make the gaskets yourself out of thin plastic sheet. This way water won't be absorbed like the cardboard gaskets ones.
PostPosted: Wed Sep 18, 2019 6:33 pm
Icecream tubs work well. And don't shrink like the cardboard does.
PostPosted: Wed Sep 18, 2019 7:33 pm
I've always painted the hinges off the doors and painted the edges of the gaskets in matching colour paint. I used to make gaskets from gasket material, but they absorbed moisture over time. As Doc said, ice cream containers, especially the flat lids, are a good source for making gaskets. I used white ice cream container lids to make gaskets for my last white car repaint.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Wed Sep 25, 2019 8:08 pm
OK, another hinge question, do you all replace old hinges or fit new pins and bushes? I don't want drooping doors! Thanks again.
PostPosted: Wed Sep 25, 2019 8:09 pm
Pins and bushes are the go. Check the threaded studs while you are there for any cross threading too.
Users browsing this forum: No registered users and 29 guests
