It is currently Wed Jul 09, 2025 4:55 am
PostPosted: Sat Sep 14, 2019 9:14 pm
Hi guys, looking for a good product to help the paper gaskets on the Mini...(water pump in this case).
Need to pick some up tomorrow morning. Likely something brush-on and non-hardening I would assume? I would love your recommended, easily available, goto product please!
PostPosted: Sat Sep 14, 2019 9:37 pm
I use Permatex Aviation Form a Gasket No3
PostPosted: Sat Sep 14, 2019 9:38 pm
This?
https://www.supercheapauto.com.au/p/per ... 0108100101
PostPosted: Sat Sep 14, 2019 9:40 pm
Morbo28 wrote:
Yep
PostPosted: Sat Sep 14, 2019 9:41 pm
Awesome, much appreciated gto. Thanks for your help! 8)
PostPosted: Sat Sep 14, 2019 9:42 pm
Or https://www.autobarn.com.au/stag-jointi ... tube-sg200
PostPosted: Sat Sep 14, 2019 9:47 pm
I used this one but I can’t comment on the results until I get the engine started
https://www.repco.com.au/en/brands/loct ... p/A1482599
PostPosted: Sat Sep 14, 2019 9:51 pm
Phil 850 wrote:
Cool, looks vintage!...reminds me of Gasket Goo, which I see Autobarn also sell...
https://www.autobarn.com.au/performance ... et-goo-85g
Is that still considered good too? Dad used to use it decades ago
Thanks!
Thats pretty much the same as the Permatex form a gasket. Have used both and recommend both.
PostPosted: Sat Sep 14, 2019 9:53 pm
Timmy funnily enough that was what I planned to use but the really crap Repco near my place was out, so I thought I'd see what alternatives Mini people use!
PostPosted: Sat Sep 14, 2019 9:54 pm
Okay good to know, then i'm sure Permatex will suit, I'll go that.
PostPosted: Sat Sep 14, 2019 11:48 pm
I use loctite no. 3.
Sent from my SM-N960F using Tapatalk
PostPosted: Sun Sep 15, 2019 2:35 pm
If you want the very best, then it is the Mercury Marine Quicksilver Perfect Seal part number 92-34227Q02. It is a non-hardening sealant similar to the Permatex aviation stuff. I have found it to be better.
You can get it at your local Mercury Marine or Mercruiser agent. They don't tend to advertise it or have it in their online shops because there is a limited customer base who use it. I can't remember exactly where i got mine, but it was a guy in a boastshed on the Parramatta River near Putney where i lived at the time.
It is more expensive than the Permatex, especially if you are only doing a single engine, because it only comes in a (US) pint can and is around AUD$65 typically, and will only last about 6 months once the can is open.
However, 10 years down the track, there are NO leaks from any of the gasket surfaces that this was applied to. This includes difficult ones like the timing cover that always seem to be too beat up to seal properly. $65 to have a leak free engine is cheap in my book.
This was recommended to me by my engine machinist and he is one of the best in the country.
Some links to sellers after a quick search:
https://www.completemarinesupplier.com.au/shop/product.cfm?categoryid=962&productid=7548
https://www.amazon.com/Mercury-Quicksilver-Perfect-Compound-93-34227Q02/dp/B007I8YFZS
https://www.ebay.com.au/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=quicksilver+92-34227q02&_sacat=0&LH_TitleDesc=0&_odkw=92-34227q02
https://www.marineengineparts.com/mercury-marine-92-34227q02-pint-can-sealer
PostPosted: Sun Sep 15, 2019 6:45 pm
Wow, I might treat myself to a can when a do an engine rebuild, thanks for the tip. Just for the water pump I've gone the permatex option.
Sent from my Pixel 2 XL using Tapatalk
PostPosted: Wed Nov 20, 2019 7:06 pm
Me again!
I am replacing diff covers, speedo drive covers etc on the gearbox after changing the final drive. I noticed that the engine builder has used an orange silicon type sealant on the gaskets.
I will of course be replacing with new actual gaskets, but would you recommend I use something similar to the orange silicon stuff or use the Permatex Aviation Sealant Liquid like I used on the water pump?
If I should use silicon, do you have a recommendation?
Thanks guys!
Users browsing this forum: No registered users and 59 guests
