It is currently Fri Jun 20, 2025 5:28 pm
 Post subject: Dellorto filter
PostPosted: Tue Sep 10, 2019 9:53 am
Ahoy all,
Dad purchased a a Dellorto DHLA 45 for mum's Deluxe over the weekend and is in need of an air filter for it.
From what I can tell the K&N 56-1690 should fit but would just like confirmation please, either that or are the Ramflo filters a better option?
TIA...
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
 Post subject: Re: Dellorto filter
PostPosted: Tue Sep 10, 2019 10:06 am
Online
I used a ramflo and a 90 degree speedo adapter, haven’t tried the KN but it’s pretty tight back there.
What engine/manifold are you using?
PostPosted: Tue Sep 10, 2019 10:14 am
Engine is a 1310. Unsure exactly the manifold that is being used, but it doesn't look too long in the runners... the car is also running the later model dash/speedo, so that opens up some space at the hole in the firewall.
Sent from my SM-G960F using Tapatalk
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Tue Sep 10, 2019 10:34 am
I'm running a Weber with a Ramflo filter with no problems to date but it can get a little fumey. I would prefer to run a slim K & N but it won't fit. BTW, love the sound of the Weber under load compared to the SU.
PostPosted: Tue Sep 10, 2019 7:37 pm
Thanks mate, I might wait until I go and see the car again, make some measurements and see how it goes on... on the plus side, a Ramflo is a shedload cheaper than the slimline K&N filter...
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Wed Sep 11, 2019 11:03 am
If you buy a ramflo it needs to be the offset one, with the holes closer to the bottom of the backplate.
minisport.com.au has them, some people on here have been caught buying elsewhere.
I use a unifilter lnx400 oiled foam pad, it flows better.
I get away without a 90° angle drive, using a Redline 3005 manifold.
PostPosted: Sun Oct 06, 2019 10:37 am
Here's the filter's we run on our Weber...They're available from Weber Performance in Melbourne and we're also running 16mm ram tubes as well.
We've also fitted a angle speedo drive as well.
PostPosted: Mon Oct 07, 2019 9:36 am
Toy444, where did you obtain your throttle body linkage?
Mark
PostPosted: Mon Oct 07, 2019 11:31 am
Mark
Hi Mark,
It's a Mangoletsi linkage kit: Weber DCOE single cable WEBLP4241 and we purchased it from Burtonpower in England.
They're 68 pounds (+ shipping).
The throttle pedal is 'awesome' and there's infinite adjustment as well...Worth the money!
Paul...
PostPosted: Mon Oct 07, 2019 12:18 pm
Mangoletsi also do a Dellorto one.
PostPosted: Wed Oct 16, 2019 12:31 pm
Toy444 wrote:
Mark
Hi Mark,
Paul...
Thanks
