It is currently Thu Jul 10, 2025 4:08 pm
PostPosted: Mon Sep 09, 2019 2:08 pm
Finally decided to move the ignition coil where it belongs. However if I mount it where it should be the bottom is touching the connections and cover of the alternator unless I mount it way up high where the bracket for it is at the very bottom of the coil itself. There must be something odd the way it mounts with my coil and bracket. Can anyone see what is wrong?
1973 Clubman GT - YG2S8 1637
PostPosted: Mon Sep 09, 2019 7:55 pm
Can you post some clearer photos Mate.
It is very hard ts see what is going on there with those photos.
However the coil does have to sit high enough to just clear the alternator. It is all a pretty tight fit
Show us some clear photos of your brackets and as much detail as you can.
PostPosted: Tue Sep 10, 2019 6:49 am
Thank you but where is a good place to host the pictures?
PostPosted: Tue Sep 10, 2019 8:49 am
Upload direct from your computer :!:
PostPosted: Tue Sep 10, 2019 9:45 am
viewtopic.php?f=25&t=10405
PostPosted: Tue Sep 10, 2019 10:56 am
This is a later set of instructions that I think are a bit easier to follow.
viewtopic.php?f=25&t=96873
PostPosted: Tue Sep 10, 2019 1:46 pm
please see attached pictures
PostPosted: Tue Sep 10, 2019 1:48 pm
I think you have the wrong coil bracket. It needs to be a single bolt hole / offset bracket style.
PostPosted: Tue Sep 10, 2019 4:13 pm
Thank you gtogreen1969, would you know where I could buy that bracket?
PostPosted: Tue Sep 10, 2019 4:16 pm
I just googled images of coil brackets and there are quite a few. Try Mustang coil bracket. Are there any speed shops in Guam?
PostPosted: Tue Sep 10, 2019 4:34 pm
Sadly none, I would need to find one even a used one would be fine :roll: anybody have one lying around????
PostPosted: Tue Sep 10, 2019 5:11 pm
You can also just bend the one you have and just use the single bolt hole.
PostPosted: Tue Sep 10, 2019 5:24 pm
Ford Econoline, Ford F150, etc.
PostPosted: Tue Sep 10, 2019 5:41 pm
No you can't, it won't provide the required offset.
