It is currently Sat Jun 28, 2025 2:40 pm
PostPosted: Tue Aug 27, 2019 9:05 pm
I had noticed this quite a few years ago when these oil filters seemed to go cheap, they started leaving the two small rubber seals that go either side of the can on the bolt, out of the box and only supplying the singular large rubber ring seal. I did an oil and filter change on my car for the first time since 2015. And things havnt changed. No small seals in the box.
Are these seals available separately? What do others use? There is going to come a time when I can no longer use the same seals over and over.
PostPosted: Tue Aug 27, 2019 9:17 pm
If you have an automatic mini the filter to use is
GFE 104 it comes with 2 rubber sealing rings
Google the part number Approx $17 -$20-00 each.
PostPosted: Tue Aug 27, 2019 9:25 pm
Nah just a cartridge filter.
PostPosted: Tue Aug 27, 2019 10:07 pm
In your position and if no-one else responds I'd see if any of the rubber "washers" on the nut/bolt/screw/ etc. stand at Repco, SuperCheap, etc. are the right size.
PostPosted: Tue Aug 27, 2019 10:19 pm
I guess another question is, is anybody still using cartridge filters anymore??? Or has everyone gone spin on?
PostPosted: Wed Aug 28, 2019 5:54 am
Nearly everyone I know has gone to spin-on, it's far less messy. They're cheaper and more available.
PostPosted: Wed Aug 28, 2019 6:46 am
Gahhhhhh. I’ve been left behind over the past decade or so...!
PostPosted: Wed Aug 28, 2019 8:47 am
Found an email from 2008 regarding this issue. This is the reply I got:
Subject: RE: Ryco Contact
Date: Mon, 19 May 2008 09:56:23 +1000
Hi Brad,
Apologies for the delay in responding, we have found that the 2 gaskets have been omitted, as you have advised.
Please accept our sincere apologies, we will have this problem rectified.
Regards,
Michael Roussety
Ryco Customer Service
GUD AUTOMOTIVE PTY LTD
245 Sunshine Road
TOTTENHAM VIC 3012
Ph: 1800 804 541
Fax: 03 9243 3366
Email: [email protected]
Website: www.rycofilters.com.au
PostPosted: Wed Aug 28, 2019 1:56 pm
Yeah I had this issue a while ago too. I took the Ryco filter back because it was useless to me without the seals. I found that Repco Silverline brand had the seals. Pretty crap from Ryco though.
TOO MANY MINIS AND NOT ENOUGH TIME
PostPosted: Wed Aug 28, 2019 2:11 pm
Interesting. Ill look into that.
PostPosted: Wed Aug 28, 2019 3:57 pm
Brad, I got the same email from the same bloke at Ryco back in 2008.
I haven't bought a Ryco filter since.
They are no longer a manufacturer, they just sell imported filters with their name on them at rather expensive prices.
PostPosted: Wed Aug 28, 2019 4:33 pm
Bugger.... Thats not very nice of them. What brand should I use in another 5-10 years time when I do a service?
PostPosted: Wed Aug 28, 2019 4:58 pm
Just buy half a dozen filters now and that should last 40-50 years.
PostPosted: Wed Aug 28, 2019 8:19 pm
Yeah I will if I can find one that includes the seals.
PostPosted: Mon Jul 19, 2021 3:43 pm
What brand of cartridge oil filter is everyone using these days?
Is the Ryco R2200P still missing those 2 seals?
