It is currently Thu Jul 10, 2025 1:36 am
 Post subject: Demister Vents - CS
PostPosted: Wed Aug 14, 2019 12:58 pm
Hi there
I am having trouble finding a set of demister windscreen vents to suit a mk2 CS heater. Does anyone know if I could use the early UK ones which are much more common and have the hose coming out from the middle v's the CS ones that are left and right? CS ones look a little slimmer to fit behind the dash vinyl I guess. I notice that minisport are now printing them with 3d printer but at $130 a side, too pricey.
Rick
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
 Post subject: Re: Demister Vents - CS
PostPosted: Wed Aug 14, 2019 2:29 pm
Got a picture?
I'm curious to what they look like. Are they the same as the black steel mk1 type?
Sent from my SM-N960F using Tapatalk
PostPosted: Wed Aug 14, 2019 2:47 pm
Pic attached. They are plastic
Ford DF LTD - 5Ltr
PostPosted: Wed Aug 14, 2019 2:58 pm
The MK2 Cooper S demister vents are plastic but are the offset type. Pretty sure the ones with a central pipe are from the later Clubman/Mini.
I have not tried the Clubman style in a Cooper S so I can't comment on that sorry.
PostPosted: Wed Aug 14, 2019 4:28 pm
I have a RH plastic vent if that's any help.
PostPosted: Wed Aug 14, 2019 7:36 pm
Moke have central
PostPosted: Thu Aug 15, 2019 9:06 pm
Goldbrocade_62 wrote:
Moke have central
I thought that too.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Fri Aug 16, 2019 5:39 am
I had some offset plastic ones, I think from early Clubman.
