It is currently Wed Jul 09, 2025 8:32 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Aussie GT Engine
PostPosted: Tue Jul 30, 2019 8:44 pm
TK wrote:
Probably not as you can re-stamp any old 1100S thick flange block
But the fuel pump hole maybe the give away
PostPosted: Wed Jul 31, 2019 11:51 am
so the 1206 didn't have a fuel pump blanking plate?
PostPosted: Sun Aug 04, 2019 7:30 am
Here is the engine number, if by chance someone is missing the motor from their car and wants to having matching numbers again.
PostPosted: Sun Aug 04, 2019 9:17 pm
Chris,
I am interested to know if that block has a hole cast above the center main, between number 2 and 3 cylinders?
Or is it solid cast?
Thanks Dave
PostPosted: Mon Aug 05, 2019 6:08 am
sitnlo62 wrote:
Chris,
Thanks Dave
Hi Dave, I’ll have a look today and report back.
PostPosted: Mon Aug 05, 2019 12:29 pm
sitnlo62 wrote:
Chris,
Thanks Dave
Has the hole in the block
PostPosted: Mon Aug 05, 2019 12:57 pm
I believe that it's only the last of the A Series that didn't have the hole. IE 1275LS and some Mokes
PostPosted: Mon Aug 05, 2019 1:06 pm
According to data in the Clubman GT Register it was probably originally fitted to a January 1973 car.
PostPosted: Mon Aug 05, 2019 4:16 pm
I have found thin flange solid side blocks (1100S manual and
auto) without the hole, and thick flange (1100S manual and auto) with.
Which means the hole came later? Me thinks...
Last edited by drmini in aust on Mon Aug 05, 2019 6:27 pm, edited 1 time in total.
PostPosted: Mon Aug 05, 2019 6:07 pm
I think that Vizard talks about the "holeless" block in one of his books
PostPosted: Mon Aug 05, 2019 8:10 pm
My spare thin flange block has no hole, I always assumed the hole appeared with the thick flange.I don't remember if my other thin flange block has it or not.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Tue Aug 06, 2019 10:05 am
Another question about these engines.
What camshaft and oil pump type did they have?
RonR
68 build Mk1 Cooper S
PostPosted: Fri Aug 09, 2019 7:32 pm
Ron,
In Dad's it was basically stock 1100S gear but who knows what had been changed since December 1972.
PostPosted: Sun Sep 15, 2019 12:48 pm
Just got another one, this time 1205/1107
PostPosted: Sun Sep 15, 2019 1:19 pm
Lucky to find a 1205 police block
Users browsing this forum: andrew9, Phil 850 and 43 guests
