It is currently Fri Jul 11, 2025 5:46 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Engine number
PostPosted: Wed Dec 09, 2015 8:46 pm
1970minik wrote:
Thanks guys
so 1275 from a Morris 1300 it is
How long will the motor last if the oil way mods and the oil pump spacer were not done?
If you don't do it you will have NO oil flow into the engine.
There is no oil way drilled for the pump outlet- auto pumps have a dirty big exit pipe behind the torque converter instead
. Oil goes down to the autobox, then back UP the banjo pipe into the motor.
The spacer is needed because the pump recess on the auto block is 1/4" deeper than a manual one.
Read my post in the how-to forum. It has pics. viewtopic.php?f=25&t=90470
Here's 2 of em-
PostPosted: Wed Dec 09, 2015 9:09 pm
You guys talking about Pedr Davis' Spotlight book? I bought that book yonks ago, had more errors than facts (not really).
Is there a corrected edition available?
PostPosted: Wed Dec 09, 2015 9:14 pm
It's Peter, not Pedr Davis.
PostPosted: Wed Dec 09, 2015 9:54 pm
http://www.bmclaheritage.org.au/Shop.html
PostPosted: Wed Dec 09, 2015 10:35 pm
winabbey wrote:
I was one of many who contributed information for the book. Since publication I've provided Peter with corrections and suggested changes, most of which have been adopted I understand. A reprint is on the way as all first editions have been sold.
I've mentioned to him the possibility of marque specific versions, such as a Mini and Moke document with only the data from the book that applies to those cars. I think Mini enthusiasts would be more likely to buy a condensed version rather than the full 290 page book.
I've emailed Peter re our current discussion. Will let you all know after we chat.
This book is like the Terry Bebbington’s 40,50,60 years of Holden books which I have and should be left as is cause its to do with bmc/leyland as a company with all there products in one book like the Holden one
Maybe the car models could have there own chapter like in the Holden one
Wonder If the people who brought the first copy could some how get the corrections and suggested changes that will be printed in the new copy from peter Davis or the book publisher
PostPosted: Wed Dec 09, 2015 10:51 pm
So is the one listed on their site the second edition as it appears you can buy it now?
Rod
PostPosted: Thu Dec 10, 2015 8:02 am
Thanks Drmini. Will read your post
PostPosted: Thu Dec 10, 2015 8:37 am
Rod
My understanding is the re-print is happening soon so they may be taking orders in anticipation. I don't know. I'll ask Peter when we talk.
PostPosted: Fri Jul 12, 2019 8:38 am
Anybody seen a 12H269B ? Still has id plate riveted on ... so obviously an import but what from ?
Is it an A+?
Simonw
Brisbane QLD
1st car - 1964 Mini Panelvan 850
Previous - 1978 Leyland LS 1275 Gold
- 1969 Mini K
PostPosted: Fri Jul 12, 2019 3:44 pm
Doesn't seem to appear in the Mini/Metro series... Inline perhaps???? Spright/Marina???
Cheers, Ian
PostPosted: Fri Jul 12, 2019 4:05 pm
12 - 1275
H - transverse
269 = Yd, Td, Ub, Pf, Kf, Sf, Ne
Mechanical fuel pump -Yd
Twin carb - Td
C40 dynamo - Ub
?? - Pf
?? - Kf
Carb crankcase ventilation - Sf
?? - Ne
There are a couple of codes I can’t find the meaning of, hopefully that narrows it down slightly
PostPosted: Fri Jul 12, 2019 5:49 pm
It’s An auto... so maybe a Nz import of some kind ?
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Sat Jul 20, 2019 6:21 am
timmy201 wrote:
12 - 1275
H - transverse
Twin carb - Td
C40 dynamo - Ub
?? - Pf
?? - Kf
?? - Ne
I can add one code:
Pf = Pre-engaged starter (when not normally fitted)
B = Positive crankcase ventilation
Seems as though it would be from the early 1970's with the C40 dynamo but its an odd spec. with a pre-engaged starter motor.
In the UK our 1275 automatics were only fitted to ADO16's at this time but so far as I can recall they all had the single HS4 carbie.
Pip, pip old boy
PostPosted: Sat Jul 20, 2019 8:08 am
5mins
Users browsing this forum: Bing [Bot] and 106 guests
