It is currently Sun Jun 29, 2025 1:01 am
 Post subject: Removing seam covers?
PostPosted: Thu Jun 09, 2005 2:11 pm
Anyone knows how to go about removing the four seam covers?
PostPosted: Thu Jun 09, 2005 2:28 pm
They are held on with small steel clips, so basically all you can do is lever them carefully off with screwdrivers., making sure you dont scratch the paint or dent the car.
A major problem with these steel clips is that when you put them on, the little barbs scratch away the paint, meaning it rusts underneath the seam cover. A good trick is to use some RTV or other adhesive to glue them on - this way they wont rust from the inside, and its much easier to get them off next time.
Mini - The Wizardry on Wheels!
PostPosted: Thu Jun 09, 2005 3:19 pm
Another issue to watch for is to make sure a previous owner hasn't braized them by tacking them at any stage along the seam - I've seen this done and it is a pain to remove them.
KB
PostPosted: Thu Jun 09, 2005 4:21 pm
is there a lot of pressure needed or they come off quite easy?
Any idea where clips are?
PostPosted: Thu Jun 09, 2005 7:32 pm
:wink:
The side cover strips were factory brazed at the top and bottom in addition to the clips.
Regards
RonR
PostPosted: Thu Jun 09, 2005 8:12 pm
They come off quite easy, once you `unbraze' the ends.. :wink:
Clips are just spread along its length.
Last time I did it I used Sikaflex 291 instead of clips. It's a 1 part polyurethane sealer, paintable, and stays flexible.. No need to braze them on either! :lol:
PostPosted: Thu Jun 09, 2005 9:31 pm
That Sikaflex is the stuff they used on my car 8)
PostPosted: Thu Jun 09, 2005 10:10 pm
Fully Sik, maaaaate! :lol:
