It is currently Thu Jul 10, 2025 10:52 pm
PostPosted: Mon Jul 15, 2019 4:19 pm
Does anyone know the minimum thickness at which 7.5 inch disc brake rotors can still be machined? Is it stamped on the rotor somewhere? I had some idea it was 10mm less than the new thickness which I seem to recall was around 6 mm. If I need new rotors which supplier is recommended?
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Mon Jul 15, 2019 6:25 pm
Sorry that should read 1mm undersize, not 10mm.
Slide
PostPosted: Mon Jul 15, 2019 6:36 pm
They are 3/8" new, minimum used to be 5/16" = 8mm.
But so cheap new now they're not worth machining.
PostPosted: Mon Jul 15, 2019 6:51 pm
These were from MKO and have MIN THK 8 MM stamped onto them. https://minikingdomonline.com.au/produc ... lubman-gt/ Only $25
