It is currently Wed Jul 02, 2025 6:06 am
PostPosted: Tue Jul 02, 2019 10:33 pm
My neighbor bought this replica looks ok no rust ,paint job rough, needs bolts tightened on doors cracked side window .The modifications have been done well.1100 motor runs well .Can drive the car with a tidy up and it will look ok .Looks like a rover grille . John Sneddon will have a look at the car next week to check the numbers.The car must have been garaged all the time as there is no rust in the boot area or anywhere else, sills are original.Drip channels have all been removed ,no cracks in panels there must be a history on this mini ??
Allen
PostPosted: Wed Jul 03, 2019 7:59 am
Hi Allen,
According to the body plate and number in the firewall its a 1968 Mini Matic - actually the 18th built. But it's had so many modifications since the factory it's difficult to tell
As mentioned in your other thread this is a replica of a Monaco rather than a Broadspeed.
This car:
Monaco - you can see the different shaped window, smooth curve on the roof:
Broadspeed - these have a completely different rear end with a Kamm tail
PostPosted: Wed Jul 03, 2019 4:20 pm
I don't think that it is a replica at all. At least I wouldn't call it a replica because (from that one picture) it doesn't look close to a either. It looks as though the C pillar and rear of the roof was modified so that the rear screen slants forward more. To accomplish that the rear side windows then needed to be modified - to cater for the height difference. In turn the back part of the roof needed to be massaged. I'd say that they would have had inspiration more from chopped hot rods.
1966 Morris Mini Minor Saloon (Dot) - 1275 Auto - Mongrel
1968 Morris Mini Van (Ivan) - 998 Auto - Mongrel
1968 Morris Mini.Matic (George) - Original
1968 Morris Mini.Matic (Charlie) - Original
PostPosted: Wed Jul 03, 2019 4:27 pm
The other photo of the rear - perhaps you could say inspired by a Monaco rather than a replica
PostPosted: Wed Jul 03, 2019 4:48 pm
It would be good to see a side view. But it definitely isn’t a replica. It’s a rear chopped car.
As you’d already know the rear lights aren’t Aussie Mini-matic as the matic has the round lights.
PostPosted: Wed Jul 03, 2019 5:07 pm
and the flappy door handles.
id say this was someones roll over repair, it look very whacky
PostPosted: Wed Jul 03, 2019 5:51 pm
Was common to convert tailights to clubbh style and door change needs a bit more metal work but with correct skills is do-able so if you are capable of doing the roof mods the door change and rear lights are a walk in the park
PostPosted: Wed Jul 03, 2019 6:14 pm
I wonder what Bill Buckle would say about someone taking a mould of one of his cars and using it in this way?...
PostPosted: Wed Jul 03, 2019 7:14 pm
Matt Read has done a replica based on a rover shell for his partner
PostPosted: Wed Jul 03, 2019 7:35 pm
PostPosted: Wed Jul 03, 2019 7:46 pm
he probably wouldn't like it, but it's definitely not from a mould of a real one
PostPosted: Wed Jul 03, 2019 7:49 pm
Hee hee...OK...I give up :lol:
PostPosted: Wed Jul 03, 2019 11:01 pm
I was going to say something similar ....
Obviously the person who did the work had to change the side windows, C pillars, roof etc so anything else is possible. I am sure that John will be able to get a better picture of the car when he sees it.
PostPosted: Thu Jul 04, 2019 8:16 am
BTW Bill Buckle is still around and active in the automotive world...who could forget his goggomobil!
https://www.shannons.com.au/club/news/i ... -treasure/
https://www.youtube.com/watch?v=fk6pO7eLeiM
PostPosted: Wed Oct 14, 2020 9:54 pm
Allen
Hi mate did he or you get any photos of the build very interested
Sent from my SM-G960F using Tapatalk
