It is currently Sat Jun 21, 2025 4:44 am
 Post subject: Help needed...
PostPosted: Tue May 28, 2019 4:28 pm
Would anybody have a water pump pulley for a suzuki G13B, or failing that, could someone measure one so that I could either get one made up or find one off a different make/model
Adam
1966 Mini 850 - Suzuki Swift GTi 1300 conversion
 Post subject: Re: Help needed...
PostPosted: Tue May 28, 2019 8:20 pm
Should be easy enough to find- lots of wreckers have the 90s swifts / barinas- I’ll bet the water pump from a g13 also fits a g13b.
PostPosted: Wed May 29, 2019 8:54 am
I have called nearly a dozen places so far, no luck yet. They all say too old! I will keep trying though.
PostPosted: Wed May 29, 2019 12:56 pm
There's one in a barina in a wreckers in Goulburn 02 4822 2000 or 02 48212694 the engine code was G13BA.
Roads need more corners
PostPosted: Fri May 31, 2019 3:02 am
I should have a couple here in my spares box.
Will check in the morning.
Assuming you want a 3 rib pulley to suit a Mk1, but you can use a 4 rib pulley with a three rib belt (as the early MK2 did).
PostPosted: Fri May 31, 2019 5:10 pm
That would be awesome awdmoke. I am having no luck with the wreckers. The drive pulley and alternator have three ribs on them.
PostPosted: Fri May 31, 2019 5:11 pm
Cool. Thanks fuzzy-hair-man. Out of interest, how did you find that? I have trawled the web looking.
PostPosted: Fri May 31, 2019 9:56 pm
I've never had much luck with wreckers via the Web or over the phone I almost always go look.
I was there just wandering about, the best wreckers have so many cars they don't know what they've got so you've got to look yourself.
Other people watch TV or shop when they're bored I wander around wreckers looking for interesting things or parts that might work.
The Hunter / Newcastle wreckers I've been to seem a bit limited, there was a good one at beresfield but I believe it's closed, I found a decent one south of Swansea on the old pacific hwy, they want a lot for bits but they had lots of cars so would be a good option. Budgewoi Auto wreckers it seems.
PostPosted: Sun Jun 02, 2019 9:57 am
Good to know. Thanks for the info. It is a crying shame Beresfield Wreckers closed down. They had heaps of stuff.
PostPosted: Tue Jun 18, 2019 10:20 pm
Try redlinegti.com it is a Suzuki GTI forum. They may have info and parts for you during this build.
PostPosted: Wed Jun 19, 2019 6:40 am
Are Suzuki GTI’s becoming difficult to find now too? I imagine 4efe and 4efte are also.
Begs the question, what other street legal engine conversions are there for a mini?
Vtec, yes but not in SA.
Daihatsu Charade, I’ve only ever heard of one.
Zulu...
1967 mini Cooper S
PostPosted: Wed Jun 19, 2019 8:07 pm
Nissan micra k11, other than that there was talk around the yaris 1.5 litre engine.
13secmini did a daihatsu 3 cylinder turbo that fitted nicely.
PostPosted: Wed Jun 19, 2019 8:41 pm
Why can you not have a VTEC mini in SA?
PostPosted: Wed Jun 19, 2019 8:43 pm
I’ve never heard of one here... but, if you can have one here in SA I’d love to do it!
Zulu...
1967 mini Cooper S
PostPosted: Wed Jun 19, 2019 10:03 pm
You may not have heard of one, but yes, you can.
There are not a lot of Vtec Minis registered in Australia yet, but there are a few under construction with at least a couple in SA.
And theres not a lot of them because they are not a simple or cheap conversion!
Don't listen to what I am saying... just understand what I mean.
Users browsing this forum: No registered users and 26 guests
