It is currently Fri Jul 11, 2025 4:10 am
PostPosted: Tue Jun 11, 2019 8:54 am
Does anyone know of somebody in Adelaide (perhaps a member here...) that has experience stripping down and rebuilding a mini engine?
I've taken the valve block off my 850 and exposed a lot of rusty crud through all the water galleries, I'd want that all cleaned out properly I think.
And when I drained the sump, there was a lot of thick syrup that came out, I'm thinking it'd be best for someone with more experience to take it to bits and rebuild it.
Or what would the folks here suggest?
PostPosted: Fri Jun 14, 2019 6:17 pm
I've got a strong little 850 that you can basically have for nothing after I fit up the new 998. Just needs a new timing chain (it's a bit rattly). Only problem is I'm in Qld.
PostPosted: Mon Jun 17, 2019 10:30 am
Thanks clip,
I'll let you know how it goes, I've decided not to rebuild but cleaned it up externally and painted it, I'll flush it with new oil until all the gunge is out.
If it doesn't look like cleaning up I'll flick you a PM!
PostPosted: Mon Jun 17, 2019 4:23 pm
don't swap the motor if the engine number matches the ID plate, you'll regret it later...
Rehmac motors do mini motors, they used to advertise in TME
Have a chat to the guys at Minisport SA (Doogie knows his stuff)
Users browsing this forum: Bing [Bot] and 72 guests
