It is currently Thu Jul 10, 2025 11:27 pm
PostPosted: Sun Jun 16, 2019 12:23 pm
I am trying to track down the whereabouts of my old Mk1 Indigo Blue I sold in 11/2002. Any help would be appreciated. I resprayed it Alfa Red externally only.
PostPosted: Sun Jun 16, 2019 12:50 pm
You could try FIGJAM. He owned it in 2005. Here are a few posts where he mentions it.
viewtopic.php?f=3&t=9151
viewtopic.php?f=2&t=6167&p=78792
It also had an extra chassis plate attached - number was NREPSD465
PostPosted: Sun Jun 16, 2019 12:54 pm
The RTA put one on in 4/2000 but it was NREPS0465Y766.
PostPosted: Sun Jun 16, 2019 12:58 pm
Yep thats the one. The photo I have was hard to read the last few digits.
FIGJAM was also chasing the original block for it back in 2005. viewtopic.php?f=9&t=6039
I haven't seen or heard of this car for a while now sorry.
PostPosted: Sun Jun 16, 2019 1:06 pm
Online
FIGJAM (Brendan) last signed on here in Dec 2005 so little point in leaving a PM, unfortunately.
PostPosted: Sun Jun 16, 2019 1:09 pm
It should still send a notification to his linked personal email address. But the logging in and remembering his password may be an issue
PostPosted: Sun Jun 16, 2019 1:14 pm
Online
I have sent an email to the address he used at that time. Will see what happens.
PostPosted: Sun Jun 16, 2019 1:17 pm
Photo removed
PostPosted: Sun Jun 16, 2019 6:52 pm
Online
It bounced, so that email address is not in use.
PostPosted: Mon Jun 17, 2019 10:44 am
I think that's my dad's car - red over indigo blue monotone, did have a dodgy looking RTA plate stamped like that on it but now registered with proper numbers in Vic
edit: probably an ex-police car
PostPosted: Mon Jun 17, 2019 10:53 am
simon k wrote:
I think that's my dad's car - red over indigo blue monotone, did have a NSW plate on it but now registered with proper numbers in Vic
Its a small world.
PostPosted: Mon Jun 17, 2019 3:02 pm
confirmed it's the same car - now lives in Ballarat
PostPosted: Mon Jun 17, 2019 3:13 pm
Online
simon k wrote:
Probably an ex-police car
Are you able to check if it has the two holes for the ID tag on the leading edge of the front parcel shelf, passenger side? If it's been recovered with vinyl you may be able to feel them from the back.
Also, lowered front seats and possibly reversing lights might be present so would be worth checking.
PostPosted: Mon Jun 17, 2019 3:28 pm
long way ahead of you Doug - yes, the holes for the ID tag are present as are the twin filament rear indicators. That's the only "hard" evidence, hence why I say "probably"
The seats aren't original, it came with an aftermarket drivers seat (now in my car) and I'm not sure what it had for a passenger seat.
Other (weak-ish) evidence is that it's a monotone colour, I gather the assumption is that the cops wanted them to look like standard minis so didn't option white roofs
PostPosted: Mon Jun 17, 2019 3:53 pm
Online
All that sounds like solid rather than weak-ish evidence. I'm not aware of any unmarked Cooper S supplied to NSW Police that was duotone, so being monotone is further supporting proof.
Check for sump guard holes (three across the front of the subframe and two each side near the drive shaft holes). Also three holes each side at the top of the front seams for the mesh windscreen, and holes in the driver's side flitch panel below the brake booster for a siren, and maybe holes for a siren switch near the driver.
I would like to know about the reversing lights wiring. What colour and trace wire, and what type of connector at the lights was used? Does it appear to be part of the body loom wrapped in black tape or separate? I have a factory drawing for reversing lights on Mark 1 cars that I'm keen to verify.
