It is currently Fri Jul 11, 2025 9:53 am
PostPosted: Sat May 18, 2019 12:02 pm
Hi everyone,
Question about input gear and bearings for a 3 synchro box.
Currently fitting a 998 A+ engine to my 850 3 synchro gearbox.
Bearing removal on the gear is obviously a 3 leg puller job once the circlip is removed, but how does everyone remove the bearing race from inside the clutch housing?
When fitting the A+ to my 3 synchro, do I utilise my input gear, idler and primary from the 850 or use the A+ ? Do A+ ones differ?
I'm planning on retaining my pre verto clutch if this helps
On a side note, there seems to be a small chip in one of the the input gears teeth on the extreme outside- see pictures. Will this affect in any way?
Happy to buy if someone has a spare they are willing to sell.
PostPosted: Sat May 18, 2019 10:08 pm
I normally heat up the clutch housing with a hot air gun and the race will drop out after a couple of minutes.
I believe the A+ gears have a different helical angle so you can't mix and match those gears.
Do you know it your 850 primary gear fits your 998 crank? There were 2 sizes for the 850 crank tails. The input gear for a 3 syncro has a longer snout so if you use the A+ gears you will need to space the input one out.
Hope that helps, good luck with your project.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun May 19, 2019 10:02 am
To remove the outer ring of the roller bearing I tack weld a flat washer and bolt inside it, then pull the out with a nut, washer and a driveshaft yoke.
Or you can run a mig weld bead inside it which will shrink the ring.
Users browsing this forum: 1071 S and 91 guests
