It is currently Sat Jul 12, 2025 12:50 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Tue May 07, 2019 1:19 pm
9YaTaH wrote:
Yes...but you grind the blade thin (carefully so it remains springy) and only use the tip to carefully pick up the iron filings ...it can be a tiresome task but well worth it if you have ever been annoyed by a "sticking" speedo
Blade cross section should look something like this...<>
Of course, the drag cup is aluminium and won't be bothered by iron. And the magnet is out of the way.
PostPosted: Tue May 07, 2019 3:27 pm
That's just it...iron filings can stop the drag cup in its tracks...especially when they are hiding in the gap between the magnet and cup and underneath the cup...be very careful tho...
Aside: a fella I know used compressed air to expunge the iron filings...I was horrified...especially as air lines can be full of water...but he got away with it! :-)
PostPosted: Thu May 09, 2019 4:13 pm
What an awesome read. My odometer stopped turning a few months back, and after reading this, I'm now 100% positive that I'm too scared to pull it apart for a look! :)
mooo, I'm a pig!
PostPosted: Sat May 11, 2019 8:06 am
Quite interesting particularly the tools. Think I might have a go at repairing a few some time
1960 Morris Mini Minor
PostPosted: Sat May 11, 2019 9:10 am
As you well know...its not for the feint hearted or those with a hangover...steady hands Grasshopper :roll:
PostPosted: Sat May 11, 2019 10:30 am
The only new parts I have found for these speedos is the chrome bezel and the glass. After that you have to rely on everything just being dirty and dried up and needing just a clean and lubricated. Parts have to be cannibalised but they are often worn out too.
PostPosted: Sat May 11, 2019 11:35 am
Ummmm slightly newer Brit cars or low mileage units can be a source of good parts that can match...not easy, but possible
Another hint...
https://mgaguru.com/mgtech/dash/st106.htm
