It is currently Sun Jul 13, 2025 1:47 am
PostPosted: Tue Apr 30, 2019 7:57 pm
Foxy1971 wrote:
On mine there is a dent in the outer gutter seam on the passenger side just above the door pillar.
BXQ122 shows both the centrally located aerial and a ,I suppose an AM Radio aerial on the D/S. I reckon they may have mounted an AM radio aerial on the passenger side just to have background music
Here is the other photo that shows the side antenna.
PostPosted: Tue Apr 30, 2019 9:34 pm
I don't think police Ss were fitted with AM radio antennas.
When we were in Bega with our S, the officer we spoke to said the patrolmen were not permitted to have a radio in their vehicle - even though it was needed to keep in communication with base station.
Maybe for BXQ it was a driver's addition considering it was a clip-on item.
PostPosted: Wed May 01, 2019 5:48 pm
Thanks again for all your words of wisdom. Now the search for a sun visor.
Oh just picked up some bits from Woodys Hydroblasting. All I can say is wow. I will put up some pick shortly. Thx Winbbey for the referral an amazing job and an eye for detail
71 MKII Cooper S
PostPosted: Wed May 01, 2019 9:27 pm
Straight from the hydro blaster
Block to come
71 MKII Cooper S
PostPosted: Wed May 01, 2019 9:34 pm
Block to come
Very pretty.
Out of interest does your gearbox have a stamped serial number on the front? They either had FAXe xxxx or they were left blank.
PostPosted: Wed May 01, 2019 10:23 pm
Macka,
What's the story with the stamping, I have 2 X 22G1128 boxes, one stamped FAXe 2441 and one which is blank.
Thanks,
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Wed May 01, 2019 10:30 pm
cgo wrote:
[quote="gtogreen1969"Out of interest does your gearbox have a stamped serial number on the front? They either had FAXe xxxx or they were left blank.
Macka,
Thanks,[/quote]FAXe is the code for the Mk2 Cooper S box fitted to the 9FXEY engines. However only half of the power plants i have seen carry the stamped gearbox serial number. The others are blank.
I am trying to collect info on the correlation between engine numbers with and without a gearbox serial number to better understand why some are blank.
Was it due to replacement gearboxes or did they just stop stamping them at a certain date?
Can you remember the engine number fitted to gearbox FAXe2441 and the engine number with no gearbox serial number?
PostPosted: Wed May 01, 2019 10:45 pm
Thanks for the info.
FAXe2441 is fitted to engine 9F/Xe/Y53725, possibly original box, Oct 69 build.
Blank is fitted to 9F/Xe/Y54732, no idea, Sept 70 build.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1982 RX-7 Series 2
PostPosted: Wed May 01, 2019 11:11 pm
Thats great. Thankyou. I have only just started to collect this info so i am a long way off working out a pattern yet.
PostPosted: Thu May 02, 2019 12:30 pm
Just had a look at car with original engine no. 9F/Xe/Y53726, doesn't have this engine now. Gearbox is stamped FAXe2444. Original engine no. is one more than mine, box 3 more, chassis number is 10 less, both cars Oct 69 build.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1982 RX-7 Series 2
PostPosted: Thu May 02, 2019 7:02 pm
I will let you know re the serial numbers tomorrow evening
71 MKII Cooper S
