It is currently Thu Jul 17, 2025 11:15 am
 Post subject: radiator coolant mini
PostPosted: Sat Mar 16, 2019 5:55 pm
What is the best one to buy ? Some say get the coolant without glycol ? Expert opinions please. I spent $8000. on the new motor.
Allen
PostPosted: Sat Mar 16, 2019 6:57 pm
I run Nulon ethylene glycol green concentrate 25% and h2o. Never had corrosion. I swap it every 4 years.
I don't trust premixed lolly water.
PostPosted: Sat Mar 16, 2019 8:28 pm
Agree with the Doc, use Nulon green concentrate and H2O in a recently rebuilt Mini engine and all of my other cars.
Dislike premixed coolant as it seems to leave a residue in system over time.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Sat Mar 16, 2019 8:47 pm
I am using Nulon Green at 30% and rain water.
You may want to run water only for the first couple of weeks flushing the system 2 or 3 times before filling it with coolant.
PostPosted: Sun Mar 17, 2019 7:31 pm
Easily mistaken for lime cordial :P
PostPosted: Mon Mar 18, 2019 1:10 pm
I was using Nulon non glycol green that I mixed with distilled water, but Nulon has disconntinued this so I've moved to the Penrite equivalent.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Mon Mar 18, 2019 3:41 pm
Yes also moved to Penrite equivalent and have always used Penrite oil.
PostPosted: Fri Mar 22, 2019 5:34 am
Is it an aluminium radiator?
