It is currently Sun Jun 22, 2025 11:07 am
PostPosted: Tue Feb 19, 2019 3:22 pm
As part of my Cooper S rebuild project, I’m going to be needing a decent stage 3/4? road/race spec 5 port iron cylinder head. Apart from Graham Russell who else in Australia can supply a performance 1275 head suitably modified with quality 35/29 valves, port and polished chambers, magnesium bronze guides, double valve springs, etc?
I have heard Martini has a good reputation but not seen any of their work first hand.
Or should I seek to procure one from the likes of MED, Slark, Calver (does he still do the MS heads?), more costly no doubt but presumably top notch stuff. Any recommendations?
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Tue Feb 19, 2019 8:27 pm
Go for the trusted GR product. Results speaks for itself a million times over.
PostPosted: Wed Feb 20, 2019 7:17 am
Or any of the other trusted cylinder head specialists in Australia.
Link Automotive (A & B series specialists)
Martini Heads (A & B series specialists)
Racepoint Developments ( A & B series specialists )
Powerplay ( A & B series specialists )
British Sporting cars (A & B series specialists)
Head Stud Developments
Tate Engines
Alex Katsikas ( A series specialist )
Wilson Automotive (A & B series specialist )
Advanced Engine Dynamics
Etc.
There are many professional A series cylinder head specialists in Melbourne.
Have a Nice Day.
PostPosted: Wed Feb 20, 2019 12:10 pm
Thanks, I don't have a 1275 head to supply/send to be modified so am looking to buy one that is already modified.
Slide
PostPosted: Wed Feb 20, 2019 1:53 pm
There is one on FB. https://www.facebook.com/marketplace/it ... 548639683/
BMC mini 1275 modified cylinder head, converted to 11 stud, high flow ports this head will suit hot road to race applications will be supplied with new 1.4 inlet valves and 1.180 ex valves, will be set up with new springs to suit the cam of your choice.
$2300
PostPosted: Fri Feb 22, 2019 5:58 am
Have you seen this , as far as i'm aware it's still for sale .
viewtopic.php?f=8&t=98144
PostPosted: Fri Feb 22, 2019 6:48 am
Try Ian Fahey in Wollongong...
PostPosted: Fri Feb 22, 2019 3:42 pm
A second for Ian Fahey beautiful work but you will have to source a head .
PostPosted: Fri Feb 22, 2019 8:21 pm
Anyone used minspares and repairs in Seaford Victoria?
PostPosted: Sun Feb 24, 2019 5:08 pm
Someone who has the passion to put hours in on a flowbench and research one type of head .
PostPosted: Tue Feb 26, 2019 8:24 pm
That pic posted looks much like a Vizarded head.
