It is currently Thu Jul 17, 2025 10:49 am
 Post subject: Half moon gearbox
PostPosted: Sun Feb 10, 2019 2:21 pm
Does this look like it’s seated properly ?
Simonw
Brisbane QLD
- 1969 Mini K
 Post subject: Re: Half moon gearbox
PostPosted: Sun Feb 10, 2019 2:35 pm
I find the best way to fit the half moon is with the front timing plate fitted. But otherwise it looks ok.
PostPosted: Sun Feb 10, 2019 2:43 pm
Great ! Thanks . :)
I did put the plate on when installing so it should be aligned
Just did;t know whether it should sit flush with face or whether the plate will compress it back when bolted down .
Thanks for the input though ,it’s reassuring
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Sun Feb 10, 2019 3:27 pm
It's a good idea to put some high temp silicon sealant in the corner where the seal and gearbox gasket meet. Also you may have to trim the end of the gasket where it meets the seal. I think not using a bit of sealant is the cause of my oil leak in this area. Next time!
RonR
68 build Mk1 Cooper S
PostPosted: Mon Feb 11, 2019 7:32 am
I use Loctite 515 or 518 anaerobic sealant or Permatex equivalent. Had no leaks.
RTV Silicone tends to get into places you don't want it.
PostPosted: Mon Feb 11, 2019 5:00 pm
Are the crankcase set-screws fully tightened yet? Looks like there's a gap to me, or is it just the Permatex oozing out? Just asking.........
PostPosted: Wed Feb 13, 2019 5:56 pm
Yes their tightened ,your correct, that’s gasket goo. Deceptive isn’t it!?
Thanks Dr , Dad has always used permetex as well . If it ain’t broke ....
Simonw
Brisbane QLD
- 1969 Mini K
