It is currently Sat Jul 12, 2025 6:49 pm
PostPosted: Wed Feb 06, 2019 3:39 pm
Is there a process to get the pump working on the car ? It works ok in the laundry sink I have water to the pump from the bottle in the car but it does not want to transfer the water to the 2 windscreen washers.
Allen
PostPosted: Wed Feb 06, 2019 4:04 pm
Do you have the one-way valve working correctly?
PostPosted: Wed Feb 06, 2019 4:55 pm
Is the tubing new or are you sure it will pass fluid? are the nozzles clear?
PostPosted: Wed Feb 06, 2019 5:46 pm
I couldn't figure how it was meant to be originally. So used a 1way valve on each side of the pump.
Sent from my SM-N960F using Tapatalk
PostPosted: Wed Feb 06, 2019 6:29 pm
There is a one way valve in washer bottle do you have that
PostPosted: Wed Feb 06, 2019 7:12 pm
Thanks ,I did not know there was a one way valve ,I will try to find out what it looks like. I need them working to get a blue slip for rego.
Allen
PostPosted: Wed Feb 06, 2019 8:30 pm
Allen
These are what I am using
https://minikingdomonline.com.au/produc ... er-bottle/
https://minikingdomonline.com.au/produc ... t-piece-2/
PostPosted: Sun Feb 10, 2019 10:54 pm
Thats what I was missing. I didnt have the t-piece with the valve in it.
Thankyou
PostPosted: Fri Feb 22, 2019 9:41 am
Probably why mine hasn't worked since I have owned the car , must go and have a look :shock: :lol: .
PostPosted: Fri Feb 22, 2019 4:55 pm
Changed mine to electric, using one of those generic pumps (same as on later models). Push button switch fits in place of the old manual job quite nicely.
To hell with originality!
PostPosted: Sun Feb 24, 2019 2:49 pm
:idea:
Can also be used in an emergency if your fuel pump fails :idea:
[with apologies to Bush Mechanics - last day of exhibition at the National Museum]
Users browsing this forum: No registered users and 118 guests
